How Long Has Your Vertical Base Station Antenna Been Up?
De_Wildfire Verified
- Handle: De_Wildfire
- Real Name: Greg
Just curious, how long has your vertical base station antenna been up and what type is it? I have an imax 2000 that has been up since 2006 with the same coax buried underground going out to the antenna. What's the history of your vertical? I guess soon,the coax and my iMAX 2000 will need replacing.
My longest owned vertical is a Avanti Sigma II (model AV-170), bought it right before Antenna Specialist bought the patent and discontinued it, think I got it in 1976 and it was discontinued in 1979. I still have it but it hasn't been up for a few years. It was up a good 30 years before ever changing the coax, the SWR went up and I found water had migrated into the braid. It is sitting in the garage, cleaned up and waiting to be installed again.
443 Arizona Verified
- Mod Duck
- Handle: Double R
- Real Name: Steve
- Radio: madison on 5/8 wave
about 35 years with same coax, still working good. plain old RG8 coax and an old Hy-Gain 5/8~
- Real Name: Greg
Wow, I still may have a few years left on it. I did use that rubberized stretch tape and wrapped it real good at the connection point. I bet the prices have doubled if I bought one today. I paid $105 at the local truck stop that also sold base antennas.
- Stoneman
- Handle: Stoneman
- Real Name: Junior
- Antenna: One Shot Dipole
- Radio: Cobra 2000 GTL
I have a Antron 99 on the roof of the garage, it's been out there since 2000, same RG8 coax...The antenna is holding it's own, only change is the color, it's like a darkest green color...
- RFHobbyist
- Handle: Lonestar
- Real Name: Michael
- Call Sign: N5RLR
- Antenna: Solarcon A99
- Radio: President George Fcc
My current antenna, a repaired, gifted Solarcon A99, has been up almost two months with RG-8X coax. The antenna is at least twelve years old; I was given it in 2015 by its previous owner when he replaced it with another vertical. I'd stored it all this time.
The aforementioned repair was replacing the SO-239 at the bottom of the downtube; its mating PL-259 had been cross-threaded with pliers and was nigh impossible to remove. I cut off the end of the tube and fashioned a bracket to hold a replacement SO-239.
Before this, the longest I'd had an antenna up was seven years, with my beloved Radio Shack Archer "Super Maxim" halfwave and RG-58/U coax.
73 de Lonestar / Michael
Southeastern Dallas County, Texas USA
"Since 1976"
"Since 1976"
- Real Name: Greg
Those A99's are great antennas. I talk to many stations around the country who run those verticals. Yesterday, at sunset, I talked to this guy in TX on his deck who was running 10 watts on with his A99 eight foot off the ground on a tripod. The frequency was clear and he was giving me a S-4.
295 antenna Verified
- Moderator
- Handle: 2950 or 295
- Real Name: Charles Reney
- Antenna: patriot, Discone
I have been using my proComm patriot 12' cb antenna for 11 years. I have made contacts all over the world.
- Real Name: Greg
295....It sounds like a very stable antenna and it keeps up with the other verticals on the market.
