Transmits OK on SSB but not AM
Critter98
Handle: 21 EW
Real Name: Dennis
Radio: Realistic TRC-492 Navaho, TRC-453, Uniden PC68LTD, Uniden President Grant, 23ch Hi-Range 1 Hi-Gain
#411672
Post by Critter98 »
Hi all. I have a Realistic TRC-453 AM/SSB radio. Modulation is great on both SBs. Throws a great carrier on AM but no modulation. I haven't taken the radio apart yet and I'd like to know what I should look for inside.
Tks in adv.
Re: Transmits OK on SSB but not AM
#411687
It is probably the AM voltage regulator, usually located on the right side chassis, doubt if there are any replacements but there are plenty of donor radios at flea markets etc., so if it is in good shape, don't toss it.
Critter98
Handle: 21 EW
Real Name: Dennis
#411705
Post by Critter98 »
Thanks Greg. I'll check it out.
Critter98
Handle: 21 EW
Real Name: Dennis
#411709
Post by Critter98 »
So if the 2SA3012 Resistor is what you're referring to as the AM Regulator, I checked that and it seems ok. PITA to take it out and put it back though. I've replaced 1/2 doz capacitors also but that changed nothing. Monday I'll be buying an ESR device that will test Resistors, Transistors, Capacitors & diodes. I saw a youtube guy using one and its a pretty simple operation.
Critter98
Handle: 21 EW
Real Name: Dennis
#411734
Post by Critter98 »
So after changing some more caps I've got the radio tx on AM now but it sounds fuzzy to the rx. I'll be changing more caps.
