Siro 2016
jessejamesdallas Verified
as long as you can get a good tight-snug fit...screws can be tightened down so there's no movement...brads???
any movement can cause arcing, static, popping sounds, and loss of ground or positive contact...
- GaRebel
- Handle: GaRebel
- Real Name: Bud
Tks for the info.
You could cut a slot in the tubing and use a quality ss hose clamp, but still install the screw to keep the tubing from telescoping into itself.
3’s
3’s
