Modulation Increase on the newer SR 497HPC, Need more than the standard variable resister allows.
ahpla374
Handle: Delta 400
Real Name: Carl Pilarczyk
Antenna: 4 element Yagi, Imax 2000, Smoking gun II Amtron 99, White Lightning
Radio: Yaesy FT990, Kenwood TS 950S Digital, Kenwood TS 450, RCI 2990 and many others
#408530
Post by ahpla374 »
I am working on a newer model of the Stryker SR 497HPC and I am having difficulty in setting the modulation above 40% by adjusting all of the required variable transistors. Is there any component that I can enhance or remove to increase the modulation on all modes? Thank you very much for any info. my email is:
Message from moderator Bozo
email removed. Please send the user a private message or reply to this post.
443 Arizona
Mod Duck
Mod Duck
Handle: Double R
Real Name: Steve
Radio: madison on 5/8 wave
Post by 443 Arizona »
another way i would try first is a mic with full modulation gain, :DJ: :angry-screaming:
otherwise, yea you could eliminate parts,might gain a bit more, might pick up more spurious crap from inside the box too. if you rewire and push the circuit harder, it might work, but, if I recall, there is a "modulation booster" kit, already put together that you can just buy and tie into your circuit.
i know you are looking for a specific answer , so i am dis-qualified on new strykers. :oops: :eek: :shock: :roll:
The potentiometers in the new boards turn 360 degs so getting it set right takes patients and the stock microphone isn’t the greatest on the Strykers I’ve been told. Some of the YouTube gurus change out the AM regulator since it is easier than searching the pc board smt’s to change a resistor in the circuit. Might try a good ranger or galaxy mic before going farther.
3’s
443 Arizona
Mod Duck
Mod Duck
Handle: Double R
Real Name: Steve
:shock: this might be a stupid question but, are you working on audio or output power? :geek: :cyclopsani: i ask because maybe your trying to achieve "swing"?
i know it takes a bit of test equipment to do work on audio.
