Imax 2000
295 antenna
Handle: 2950 or 295
Real Name: Charles Reney
Antenna: patriot, Discone
Radio: Stryker 955 , Browning Mark iv
Imax 2000
#408358
Post by 295 antenna »
Would using star washers between the sections cause an swr change does anyone know.
Also coating the imaxx with flex seal. Is that a cause for higher swr as anyone does this?
By high I mean 2.10
warlock35po
Handle: Warlock35Po
Real Name: Don
Call Sign: VE1CSP
Antenna: Beam and/2 wave Dipole
Radio: Kenwood 570 D G
Post by warlock35po »
408358.Short answer, no and no.Regards,warlock35po. VE1-CSP
295 antenna
Handle: 2950 or 295
warlock35po wrote: March 11th, 2022, 2:51 pm 408358.Short answer, no and no.Regards,warlock35po. VE1-CSP
thank you
tramd
Handle: Drifter
Real Name: Brian
Radio: Tram
Post by tramd »
If it's a newer one, I believe they are shorter than the older ones and can't be set up for 11 meters. They are just for 10 meters now.
295 antenna
Handle: 2950 or 295
tramd wrote: March 12th, 2022, 9:54 am If it's a newer one, I believe they are shorter than the older ones and can't be set up for 11 meters. They are just for 10 meters now.
It's an old one. My buddy got a new one and they had to send him another foot long extension to use for 11 meters
First, I prefer a regular lock washer over the star in certain application, example on this type of antenna out in the elements a star washer doesn't seal well so water can wick into the antenna. I use a conductive grease on the joints to help prevent this from happening.
Second, yes it would be fine if you seal the joint, not with "flex-seal" but a good self sealing electrical tape similar to what the electric company uses.
Last, no it shouldn't change the SWR unless it increases or decreases the length of the antenna.
