Message from moderator Bozo
Still getting antenna warning light
- Worster
- Handle: MisterWorster
- Real Name: Patrick
- Antenna: Wilson 2000
- Radio: 2 tin cans a string
Hey guys got an issue I can’t seem to figure out, I got a Cobra 29 with an SWR of 1.3 Wilson trucker 2000 antenna. I’ve tried 3 different radios 2 Cobras, and a Mirage MX-36, a new coax, put a new mounting bracket it. All the radios will pop the antenna warning light on, it’s better now that I moved the mount, my antenna is above the cab and 12” away from anything. I’ve never had anything like this happen before
This topic was moved from the talk to CBRT admin form to general questions
My Bare feet:
Magnum S-6 Tuned by Clays Radio Shop Road King 56 (Sold)
Connex 4600 Turbo, Clays Radio Shop Road King 56 (Sold)
Connex 3400 HP, Sparkys CB Shack, Astatic 636L
2 Single Coil Predator 10K 12 inch shafts
"I'm Just a Matchbox Car playing in a Tonka Truck World"
[ external image ]
[ external image ]
Marv Verified
- BOTS R US
- Handle: Marv-the-Mouth
- Real Name: Marv
- Radio: Cobra 19 Plus
Howdy Worster,
I'm the CBRT Robot and I've just notified [Please login or register to view this link] of your new topic; "[Please login or register to view this link]". We would appreciate the opportunity to respond to your post in a timely manner. We will have one of our qualified [Please login or register to view this link] reply to this post as soon as possible (Within 72 hours). You may want to check out our [Please login or register to view this link] while you wait for our most common questions. If more info is needed from you; we may attempt to contact you by your phone number, e-mail, or via private message. Please make sure that your [Please login or register to view this link] is up to date with your contact details.
- Gold Diamond
- Handle: Gold Diamond
- Real Name: Robert Morley
- Call Sign: KE0UWN
- Antenna: HF Alpha HD-FMJ tripod mounted, Diamond X100A
- Radio: HF Yaesu FT-891, Yaesu FTM-100D (VHF/UHF), President McKinley CB
My first thought is plug a 5W dummy load into the SO-259 connector on the radio and check for the "red light" when TX'ing. If you have a SWR/RF meter then connect that instrument inline to the radio antenna connection and move the dummy load to the SWR/RF antenna connection. If the red light continues I would carefully check the radio's antenna connector and chassis wiring to the connector. Possible short. Hope this helps.
jessejamesdallas Verified
sounds like a antenna mount grounding problem.
Sounds like a short causing the problem, it could be at a length where it is resonant, that is why the SWR reading doesn't show bad on a meter but still bad for the radio. It is possible it is the antenna, find someone you can switch out one day to do a quick check. Find someone with a analyzer to diagnose it.
- Worster
That’s what I was thinking too, I’m thinking maybe the door isn’t grounded well enoughjessejamesdallas wrote: September 11th, 2021, 12:46 pm sounds like a antenna mount grounding problem.
My Bare feet:
[ external image ]
[ external image ]
