New RCI 2950 CD
- cecil
- Handle: Tree Farmer
- Real Name: Justin
- Antenna: Sirio Tornado
- Radio: Grant LT, Cobra 148, 2950 RCI
New RCI 2950 CD
I received my new 2950 in the mail the other day from GI Joe's. Easy radio to navigate and the large frequency display is nice too. Only thing i don't like is that it has more white noise than what my Grant has. Switching between the two, i can definitely tell a difference. Anyone have any remedies?
73's
Waving from the sugar maples in central MA!
304 a.k.a Tree Farmer
Grant LT
2950 RCI
Cobra 148
Grant LT
2950 RCI
Cobra 148
It is a big difference in circuitry between those 2 radios, for one the Grant doesn't have to be as wide open to receive 10 through 12m frequencies, plus no FM circuit. I have found the Rangers are pretty sensitive in receiving low signals. To help eliminate some (man made noise) check around the house for interfering signals. Wall warts, fluorescent lights, some LED's, laptop chargers, etc., might not even be in your house but any neighbor within a distance on the same transformer. You could try a "DSP" speaker to clean up some of the receive hash.
- Gunner357
- Handle: Gunner357
- Real Name: Rick
- Call Sign: KE8PSI
- Antenna: Preditor 10k, V58 Maco base,EFHW-8010 end fed
- Radio: Yaesu FT920,Galaxy 88hl, Galaxy 99v, Cobra148gtl modded, Cobra 29ltd chrome
You can make yourself a SNIFFER like I did makes it easier to find the noisemakers .... Use a 6 foot wooden pole or scrap trim with 18ft Coax tie wrap the coax to the pole leaving a foot of the center wire of the coax expose off the end of the pole hook the other end to your radio start walking the room or around the vehicle when you find the the noise maker you can try added Capacitors between the POS + and Neg - if it in a vehicle (12v) to reduce the noise. A/C i never had an issue there, So not sure what to use. But just keep sniffing around you will find the noise... I made one for my mobile with an AMP and a Export Galaxy It found all the noise makers and I put CAPS on them and it really reduced the Noise
Last edited by Gunner357 on September 28th, 2020, 10:49 am, edited 2 times in total.
Yaesu FT920 (KE8PSI)
Galaxy88hl
Galaxy 99v
Cobra148 GTL w/ channel expansion
Cobra 29ltd Chrome
Magnaforce 350
Predator 10k
V58 Maco
Homemade Dipole base antenna
EFHW-8010 Multi-band End Fed Half Wave Antenna
Galaxy88hl
Galaxy 99v
Cobra 29ltd Chrome
Magnaforce 350
Predator 10k
V58 Maco
Bombero Verified
- Handle: Boogieman
- Real Name: Bombero
- Antenna: 2ft Wire hanger
- Radio: RCI 2950 Mirage
It would be a great idea to explain to him what a ‘sniffer’ is.Gunner357 wrote: September 28th, 2020, 9:51 am You can make yourself a SNIFFER like I did makes it easier to find the noisemakers ....
Bombero
383 Boogieman
- Gunner357
- Handle: Gunner357
- Real Name: Rick
- Call Sign: KE8PSI
I wasnt done yet had to walk away but hit enter without thinking sorry
Galaxy88hl
Galaxy 99v
Cobra 29ltd Chrome
Magnaforce 350
Predator 10k
V58 Maco
Galaxy88hl
Galaxy 99v
Cobra 29ltd Chrome
Magnaforce 350
Predator 10k
V58 Maco
- Bluerunner
- Handle: BlueRunner
- Real Name: Mike
- Antenna: Starduster
- Radio: Cobra 142
Does the new radio have a more sensitive receiver maybe?
- Bluerunner
- Real Name: Mike
- Radio: Cobra 142
Try a shorted 1/4 wave stub with the shorted end grounded. Sometimes it will eliminate noise from the antenna.
- cecil
- Real Name: Justin
Hey Gunner- got a pic of that sniffer...or what it it is made from?
73's
Grant LT
2950 RCI
Cobra 148
Grant LT
2950 RCI
Cobra 148
- cecil
- Real Name: Justin
? Possibly, i like SSB, and it sounds more like AM in some respects.Bluerunner wrote: September 28th, 2020, 1:33 pm Does the new radio have a more sensitive receiver maybe?
73's
Grant LT
2950 RCI
Cobra 148
Grant LT
2950 RCI
Cobra 148
- cecil
- Real Name: Justin
This is set up as base. So a looped end of coax, have to try it! Maybe i can try the ferrite wraps too...I just need to find them around here. ThanksGunner357 wrote: September 28th, 2020, 9:51 am You can make yourself a SNIFFER like I did makes it easier to find the noisemakers .... Use a 6 foot wooden pole or scrap trim with 18ft Coax tie wrap the coax to the pole leaving a foot of the center wire of the coax expose off the end of the pole hook the other end to your radio start walking the room or around the vehicle when you find the the noise maker you can try added Capacitors between the POS + and Neg - if it in a vehicle (12v) to reduce the noise. A/C i never had an issue there, So not sure what to use. But just keep sniffing around you will find the noise... I made one for my mobile with an AMP and a Export Galaxy It found all the noise makers and I put CAPS on them and it really reduced the Noise
73's
Grant LT
2950 RCI
Cobra 148
Grant LT
2950 RCI
Cobra 148
Bombero Verified
- Handle: Boogieman
Hey..
Good info.
Bombero
Good info.
Bombero
383 Boogieman
- Gunner357
- Handle: Gunner357
- Real Name: Rick
- Call Sign: KE8PSI
No pic i can get one if ya want...... But its really simple 6 foot piece of wood scrap trim or a broom handle tape or wire tie 18' of any coax RG58/RG8x (the length of coax is just so you can move around what your working on or reaching for fluorescent fixtures) , Strip about a foot of the the outer insulation and braid off leaving the center wire/dielectric loose from end of wood ( the wood just acts as a long handle) attach other end to your radio that's all ya need it will pick up any electric noisececil wrote: September 28th, 2020, 5:30 pmHey Gunner- got a pic of that sniffer...or what it it is made from?
Galaxy88hl
Galaxy 99v
Cobra 29ltd Chrome
Magnaforce 350
Predator 10k
V58 Maco
Galaxy88hl
Galaxy 99v
Cobra 29ltd Chrome
Magnaforce 350
Predator 10k
V58 Maco
- cecil
- Real Name: Justin
Gunner357 wrote: September 28th, 2020, 9:09 pmNo pic i can get one if ya want...... But its really simple 6 foot piece of wood scrap trim or a broom handle tape or wire tie 18' of any coax RG58/RG8x (the length of coax is just so you can move around what your working on or reaching for fluorescent fixtures) , Strip about a foot of the the outer insulation and braid off leaving the center wire/dielectric loose from end of wood ( the wood just acts as a long handle) attach other end to your radio that's all ya need it will pick up any electric noisececil wrote: September 28th, 2020, 5:30 pmHey Gunner- got a pic of that sniffer...or what it it is made from?
[/qu
I have some, lets say useless RG 58 laying around, I'm going to try it. Thanks
73's
Grant LT
2950 RCI
Cobra 148
Grant LT
2950 RCI
Cobra 148
- Gunner357
- Handle: Gunner357
- Real Name: Rick
- Call Sign: KE8PSI
yeah thats what I use i had a old 1000 Wilson i cut the coax offcecil wrote: September 29th, 2020, 8:37 pmI have some, lets say useless RG 58 laying around, I'm going to try it. ThanksGunner357 wrote: September 28th, 2020, 9:09 pmNo pic i can get one if ya want...... But its really simple 6 foot piece of wood scrap trim or a broom handle tape or wire tie 18' of any coax RG58/RG8x (the length of coax is just so you can move around what your working on or reaching for fluorescent fixtures) , Strip about a foot of the the outer insulation and braid off leaving the center wire/dielectric loose from end of wood ( the wood just acts as a long handle) attach other end to your radio that's all ya need it will pick up any electric noisececil wrote: September 28th, 2020, 5:30 pmHey Gunner- got a pic of that sniffer...or what it it is made from?![]()
Reason: Fixed bbcode quote error
Galaxy88hl
Galaxy 99v
Cobra 29ltd Chrome
Magnaforce 350
Predator 10k
V58 Maco
Galaxy88hl
Galaxy 99v
Cobra 29ltd Chrome
Magnaforce 350
Predator 10k
V58 Maco
- Remington160
- Handle: Remington
- Real Name: Isaac
- Call Sign: KK7LNT
- Antenna: Max 2,000
- Radio: SBE Sidebander 3
All the rci ranger radios have a higher white noise level on receive than the older radios.
It's just the way they are.
Some people don't like it, and some people are not bothered by it at all.
I guess what Im saying is that it's normal for these radios.
- cecil
- Real Name: Justin
Thanks, i guess im just used to it now. Great radio.Remington160 wrote: December 27th, 2020, 4:40 pm All the rci ranger radios have a higher white noise level on receive than the older radios.
73's
Grant LT
2950 RCI
Cobra 148
Grant LT
2950 RCI
Cobra 148
Bozo Verified
- Handle: Bozo The Clown
- Real Name: James
- Antenna: Monkey Made MM9
- Radio: General Lee Radio
I know what a sniffer is...
- cecil
- Real Name: Justin
73's
Grant LT
2950 RCI
Cobra 148
Grant LT
2950 RCI
Cobra 148
