Browning MkIII / MkIV Audio Mods
- bushpusher
- Handle: bushpusher
- Real Name: Boris
- Antenna: max2000
- Radio: tram
Are there any proven transmit audio modifications for both the Browning MkIII and MkIV. I did a search but there isn't much info on these old boat anchors. Searching the web there isn't any concrete mods that are reversible. I did see a mod to disable the audio clipper in the MkIV but not much else. I don't have interest in rack gear or injection, just something to maybe improve the frequency response or increase the modulation %. If anyone can steer me in the right direction as far as information I would appreciate it. Thank you.
-- Saturday, 26 December 2015, 15:25 PM --
Anyone, with any idea....?
- dirtyjob
- Handle: dirtyjob
- Real Name: Mark
- Radio: Many
just curious what your running now for a mic ?
"LISTEN FOR THE PING"
Gizmotchy G-31 Beam
Super Penetrator 500 5/8 Wave
Comet GP9 2 meter/440
CBRT 18204
Gizmotchy G-31 Beam
CBRT 18204
- bushpusher
- Real Name: Boris
- Antenna: max2000
- Radio: tram
I have a few mics wired to my Brownings...D104 both powered and not, 776, echomax 2000. They all seem to work well on the MkIII. I can't seem to adjust the clipper/audio sensitivity properly on the MkIV, so nothing I try really sounds good.
I've only had limited experience with the Browning radios but I found the MKIV had a tad more bass in it's design, I was using a TUG8 D104 at the time. If it hasn't been done capping is the first order of business especially in the audio circuit, second would be tubes.
- bushpusher
- Real Name: Boris
- Antenna: max2000
- Radio: tram
I have a bunch of high quality 63v caps that I am going to install in place of the originals. I will probably use modern axials to replace the twistlocs under the chassis. Thank you.
