Alternator help
• Page 1 of 1
- Rabbit Ears
- Handle: Rabbit Ears
- Real Name: Cliff
- Call Sign: WW153
- Radio: RCI 2995DX CF
Alternator help
Post by Rabbit Ears »
I've got the standard alternator on my 1996 f250 7.5L.... Can I kit that alternator for higher output. I'm pulling an RV. I can do the work.
Help....!
Help....!
USA FOREVER
RCI 2995DX CF (PRIMARY BASE)
Turner Super Side Kick
BIRD 43P
HY-GAIN SPT-500 antenna
BIRD 43P
- Handle: 581
- Real Name: Andrew
- Antenna: sirio p5000
- Radio: galaxy 98 vhp
Re: Alternator help
I not sure they even make rebuild kits anymore but I remember them from years ago. The kits (bearings, brushes, etc.) had new diodes and rectifier bridge and they did increase the amperage some but you are using the same windings. I think it would be best to find a rebuilt unit, they almost have twice the stock amperage.
- rickk
- Real Name: rick kay
- Antenna: Francis/Breedlove
- Radio: Galaxy DX979
Re: Alternator help
NAPA often has HO alternators in their books.
If you are pulling an RV, sounds like you would be driving lots of miles. Plenty of time for charging. Your circumstances might be unique but wondering why you need more alternator output? Most high current needs are intermittent use.
Might possibly be better to spend money on a bigger primary battery and also install an auxiliary battery. Anderson Power Products makes a nice, efficient, painless-install battery isolator if needed. There should be a ton of room on your right side frame rail to put a really big auxiliary deep cycle battery. The RV I would assume has plenty of room for batteries as well.
Do you need more power when you are driving, or need more power when you are parked?
Rick
Rick
- Rabbit Ears
- Real Name: Cliff
- Call Sign: WW153
Re: Alternator help
Yes, I'll be getting the bracket and the larger alternator. Will also be using a pair of Trojan T105 wired in series for the camper. The old 1996 F250Hd 4x4 has a tow kit. When I turn the key off, that isolates the camper from the truck.
I'll go dual Optima AGM batteries in the front end of the truck. Tough and spill proof too. That'll do quite nicely for the work lights and the KC lights.
USA FOREVER
BIRD 43P
BIRD 43P
• Page 1 of 1
Jump to
- Welcome and Community
- Skip Shooter's Paradise
- ↳ General Discussions
- ↳ Watergates & Videogates
- ↳ Shooting Skip
- ↳ Hall Of Fame
- ↳ Journal
- Radio Help
- ↳ Intro To Radios 101
- ↳ General Questions
- ↳ Base Setups
- ↳ Competition Rigs
- ↳ Charging System
- ↳ Mobile Setups
- ↳ Antenna Help
- ↳ Microphone Info
- ↳ Radio Modifications
- ↳ Sideband (SSB)
- ↳ Tube Radio Equipment
- ↳ Other Technical Questions
- ↳ Miscellaneous Radio
- Buy / Sell / Trade
- ↳ For Sale Area Rules
- ↳ For Sale Area
- ↳ eBay Shopping
- ↳ Amazon Shopping
- ↳ Trade Equipment
- ↳ Wanted Radio Equipment
- ↳ Positive Feedback
- Off Topic
- ↳ Miscellaneous Chat
- ↳ Computer Help
- ↳ Signature Test Area
- The White House
- ↳ Ask Marv
- Home
- All times are UTC-06:00
- Cookie-Settings
- Delete cookies
- About us
- Downloads
- Contact us
