When submitting a question for HELP with a problem the following needs to be answered to allow the CBRT Forum Moderators,Techs, and other CBRT Forum Member's to help you resolve your problem/problems.
~ Is the Antenna / Amp / Radio 100% Stock from the Factory with NO Alterations / Modifications?
~ Make of antenna / amp / radio?
~ Model of antenna / amp / radio?
~ Mode's of operation the problem exists on ie: AM / FM / LSB-USB?
~ Is it used for Base or Mobile operation or Both?
- Is problem noticed in Mobile or Base use or Both?
~ Is problem Constant or Intermittent or both?
~ Describe as precise as you can what problems you are having.
~ Does radio have proper power if in mobile use and proper fuses installed?
~ Has the Stock modulation settings been adjusted and are you using the Stock mic or an after market mic and is the mic a Power Microphone?
~ Has the radio been peaked/tweaked or had other modifications?
~ Are you the original purchaser/owner of the antenna / amp / radio or did you get it used?
~ List “ALL” modification’s that have been performed to the radio. ie: Super swing mod, NPC mod, transistor swap and any and all parts that have been upgraded or swapped.
~ Is Antenna / Amp / Radio properly installed if mobile, and is radio properly grounded?
~ Is radio properly installed if using it as a base radio and properly grounded?
~ Have you checked all antenna’s, coax, jumper's, meter's, and installation to make sure everything is in good working condition and properly installed?
~ Where you using an amplifier when you first noticed the problem?
~ What accessory equipment do you have in line with the radio, ie: meter’s, amp, low pass filter’s etc?
~ And list any other helpful information that may help other's to help you resolve the problem you are having.
Troubleshooting help
Here is a great place to start your learning process or for you experts to give advice.
Locked
1 post
• Page 1 of 1
- Bombero
- Handle: Boogieman
- Real Name: Bombero
- Antenna: 2ft Wire hanger
- Radio: RCI 2950 Mirage
383 Boogieman
Locked
1 post
• Page 1 of 1
Return to “Intro To Radios 101”
Jump to
- Welcome and Community
- Skip Shooter's Paradise
- ↳ General Discussions
- ↳ Watergates & Videogates
- ↳ Shooting Skip
- ↳ Hall Of Fame
- ↳ Journal
- Radio Help
- ↳ Intro To Radios 101
- ↳ General Questions
- ↳ Base Setups
- ↳ Competition Rigs
- ↳ Charging System
- ↳ Mobile Setups
- ↳ Antenna Help
- ↳ Microphone Info
- ↳ Radio Modifications
- ↳ Sideband (SSB)
- ↳ Tube Radio Equipment
- ↳ Other Technical Questions
- ↳ Miscellaneous Radio
- Buy / Sell / Trade
- ↳ For Sale Area Rules
- ↳ For Sale Area
- ↳ eBay Shopping
- ↳ Amazon Shopping
- ↳ Trade Equipment
- ↳ Wanted Radio Equipment
- ↳ Positive Feedback
- Off Topic
- ↳ Miscellaneous Chat
- ↳ Computer Help
- ↳ Signature Test Area
- The White House
- ↳ Ask Marv
- Home
- All times are UTC-06:00
- Cookie-Settings
- Delete cookies
- About us
- Downloads
- Contact us
