d&a 250 maverick
- drunk monkey
d&a 250 maverick
i have a 250 maverick when you first tune it .it will do 500watts but when it sits for a few a key it up it drops down to 300watts but then you can key up and talk 5 or 6 times really fast it will slowly climb back up to 500watts
thats
thats
- tubehead
- Real Name: robert
- Radio: $5 cb
sounds like bad filter caps in the power supply reforming. you may need to get a tech to replace the filter caps.
waving a hand from the bikini state..
thumper's out!
thumper's out!
- Nagant
- Real Name: Paul
- Antenna: M104C, V-Quad
- Radio: To Many To List
Sounds more like weak tubes. I'd have them tested on a calibrated mutual conductance tester. If the filters in the power supply were going bad there would likely be an AC hum on transmit. If they were bad one or more would be either open or dead shorted.
- Flattop
- Handle: Flattop
- Real Name: Rocky Francisco
- Antenna: Home made Beam
- Radio: Galaxy base
When my da 250 acted like that it was the glass
- tubehead
- Real Name: robert
- Radio: $5 cb
i picked one of these up at a hamfest two weeks ago for $20. it got a smoked relay, some overheated resistors, and probably flat tubes. luckily i think i have everything i need to revive it in my junk piles. i was reading up on them and did see some stuff about weak caps causing low output.
i just sanded down the cabinet last night and started giving it coats of enamel. the chassis had been rained on so its drying out in the carport for now. i'll keep you guys posted on how this comes along. as long as the transformers arent smoked, i can revive it.
thumper's out!
thumper's out!
Im trying to upgrade a DA Maverick Dual Power, it works great now but I would like to upgrade tubes, etc. to get some more output. I have read a few guys that have done "things" to these and are getting around 1000w out of them, any ideas?
Snowman
Snowman
- Night Crawler
If the power transformer in that amp can't supply more voltage or current then it's capable of now even if you upgrade the tubes it will still show the same amount of wattage.420Snowman wrote: I would like to upgrade tubes, etc. to get some more output.
Wattage is calculated V x I = P where V = voltage I = current and P = wattage
As an example if the transformer can only supply 700 volts at 200ma maximum, the wattage would be 140 watts.
But if it were able to provide 700 volts at 300ma and the tubes that are in there now are only drawing 200ma at maximum output if you upgrade them to tubes that can draw 300ma then the wattage would be 210 watts.
Maybe you can get more output with different tubes maybe not it all depends if the power transformer is capable of providing the voltage and current demand of the tubes used for the upgrade.
- preacherman
- Handle: Preacherman
- Real Name: Bob
- Call Sign: K0EIR
- Radio: Cobra 29, Lincoln, Magnum
I've got a maverick 250 dual power with tubes that have quite a few hours on them
and it falls off a little on a long key down. Still will do about 700 pep with a Cobra 29
w/a mosfet driving it. Great amp...great audio and just keeps on tickin'. I've had a couple
of very clean Palomar 300a's and they are gone but the old Mav is still here.
Preacherman
Preacherman
Modifying Cobra 29's is my hobby.
- dime196604
- Handle: none
- Real Name: Dustin 664
- Antenna: Will1000
- Radio: Omegaforce S45HP
Are tube amps cleaner on the output? Do they cause a lot of interference in home stuff like computer speakers or TV's like pills do?
- preacherman
- Real Name: Bob
- Call Sign: K0EIR
It depends on the unit. Tubes overload more gracefully than transistors and
tend to put out even order harmonics when they do as opposed to transistors that
do odd order harmonics that are harder to listen to. If you have a decent amp and
don't overdrive it...plus put a relatively clean signal into it, you should be fine.
Preacherman, If you getting 700pep out of yours than something is not right with mine I guess. I am getting right at 350 on a bird meter, have you changed the caps on yours?
Snowman
Snowman
Yea, gonna start with re capping and test, then see if I want to put tubes in it or sell it and get something better.
Snowman
Snowman
- crazy_cooter
- Real Name: Tyler Sanders
- Antenna: Penetrator 500
- Radio: Browning Mark III
What kind of meter are you seeing 700 watts with a maverick 250?preacherman wrote:I've got a maverick 250 dual power with tubes that have quite a few hours on them
Preacherman
Agree, I thought mine was weak....crazy_cooter wrote:What kind of meter are you seeing 700 watts with a maverick 250?preacherman wrote:I've got a maverick 250 dual power with tubes that have quite a few hours on them
Preacherman
Snowman
Sent from my Grim Reaper powered HTC.
- Nagant
- Real Name: Paul
I just recently sold an older grey case Maverick 250 that would only do 500 to 550 on my Palstar meter. All the tubes tested excellent on my B&K 707 tester as well. No twp are exactly the same. Some will do a bit more than others and then there is meter differences to take into account as well as peak input drive. On my old Welz meter, same as the Yaesu YS-60, I would see more PEP output from larger amps then on my Palstar meter. We aren't dealing with what I would consider precision meters or equipment in general.
- crazy_cooter
Your absolutely right, I have a great example to back this theory up! I had a Paradynamics 3 window wattmeter...you know the ones you buy for 99.00 out of the C----r Catalog? Well anyways, it showed my D&A Phantom was doing a whopping 1,500 watts of swing! I thought, WOW! I got a monster here! Then I got curious and borrowed a friends Dosy that was 6 months old and barely used. We compared the two, and found out that the dosy claimed my amp was putting out like 1,250-1,300 watts swinging. Then I got severely ticked off and went 4 counties west of me to a ham operator friends house and borrowed his Bird Wattmeter. There's no arguing Bird watts, what a bird says...is what it is, PERIOD! My amplifier is only swinging 850 BIRD watts, not a watt more. So I hope my experience goes to show you just how inaccurate one meter is from the next! If you have a friend with a Bird meter, let me know what your Maverick 250 is REALLY doing for wattage, you'll be in disbelief but it is what it is.
