102 Question
Ronnie151
Real Name: Ronnie
Antenna: A-99
Radio: ICOM 728
102 Question
#233506
Post by Ronnie151 »
I put my 102 up on a 20 foot pipe yesterday, swrs are 1.5 its about 20feet away from my A99. Problem is it doesnt seem to get out very far, have it hooked up to a Cobra 148, has good ears but not much distance. Last night had both radios on at the same time, one local guy puts 7s 0n the A99 and 3s on the 102. Seems normal until another guy that puts 9s on the A99 was putting 20s on the 102. Any ideas here?? Thank you
Cobra 29, 23 channel
Uniden Grant
Uniden PC 68 XL--PHILLY
Icom-728
Uniden Bearcat 680
#233567
Post by 'Doc »
Directional?
Ronnie151
Real Name: Ronnie
Antenna: A-99
Radio: ICOM 728
Post by Ronnie151 »
no just a stainless 102 whip
Uniden Grant
Icom-728
Uniden Bearcat 680
#233582
Post by 'Doc »
Actually, I was thinking that it could be because it was directional, nearness of both antennas. If you know where those people you were talking to are located, and how that relates to how the antennas are situated. See where I'm going with that?
Circuit Breaker
Handle: Circuit Breaker
Real Name: Stephen
Call Sign: K7CB
Antenna: OCF Dipole
Radio: HR2510/Yaesu FT-950
Post by Circuit Breaker »
I'm thinking there are two reasons. 1) There's no ground plane for the 102. 2) The A99 is a half wave antenna, whereas a 102 with ground plane is simply a quarter wave. A half wave will receive better than a quarter.
Yaesu FT-950
Yaesu FT-8100
Uniden Washington Base
Uniden HR-2510
Icom ID-92 HT
SteppIR 40-6M Yagi
OCF 75/80M dipole
Antron 99
Double D
Real Name: Anonymous
Antenna: Isotropic Radiator
Radio: 2 Cans and a String
Post by Double D »
I'm thinking takeoff angle. The A99 has a lower takeoff angle than a 1/4 wave antenna, so it's possible that the signals you were receiving were coming in at angles that were favorable to each antenna. :?:
"To acquire knowledge, one must study;
but to acquire wisdom, one must observe."
Ronnie151
Real Name: Ronnie
Antenna: A-99
Radio: ICOM 728
Post by Ronnie151 »
Then why does the one guy , put a 9 on the A99 and a 20 on the 102?? I guess a 102 is a bad idea for a secondary base antenna. The A99 is at leat 20 feet higher than the 102 .
Uniden Grant
Icom-728
Uniden Bearcat 680
Ronnie151
Real Name: Ronnie
Antenna: A-99
Radio: ICOM 728
Post by Ronnie151 »
Gonna go up another 10 feet with the 102 to see what happens then. Have a D-104 on both radios but the Cobra with the 102 sounds kinds small next to the Ranger and the A99, even at only 1/2 mile away.
Uniden Grant
Icom-728
Uniden Bearcat 680
Ronnie151
Real Name: Ronnie
Antenna: A-99
Radio: ICOM 728
Post by Ronnie151 »
Just wondering, you think a 4 foot firestick would do better than the 102??? I could steal the one of my 14 year old sons bikecycle, he has a small Midland with dual antennas on it. Uses little rechargble batters to power it. It get out better than the 102 believe it or not. Gonna have to learn how to post a picture. lol
Uniden Grant
Icom-728
Uniden Bearcat 680
damage855
Handle: Hanker
Real Name: Justin
Post by damage855 »
you might be a redneck if you have a CB with twin antennas on a bicycle. LOL sorry couldnt resist.
Tinman590
Real Name: Andy
Radio: Icom and RCI-2980
Post by Tinman590 »
I gotta see a picture of that bicycle
RCI-2980WX
Henry Radio 2k2
Imax 2000
4 element maco
RCI-2950 twin tube modulator
Cobra 2000
Washington
A bunch of other stuff
Secret Squirrel
Handle: Secret Squirrel
Real Name: Joseph Husk
Antenna: Hustler HQ-27 Magnum
Radio: Stryker 89MC in mobile
Post by Secret Squirrel »
Dual 102 inch whips on the Wheel Horse Garden Tractor is the way to go.
Secret Squirrel
"Talking to the USA from my Archer Space Patrol walkie"
#233946
Post by 'Doc »
Will an antenna half the size of a 102" whip out perform that 102" whip? Not if the whip is set up correctly. That 102" whip, or that 4 foot antenna, by themselves, are only half of a complete antenna. Put the 'other' half where it's supposed to be and either ought to work okay.
p71vic
#233981
Post by p71vic »
You mean you gotta have a ground plane ?
Just kidding.
Any antenna requires the up side, ( 102 ) and a base. Metal car, shed, cookie pan.
Kinda needs to be equivalent in area.
Mag mounts use capacitive reactance . 1 / 2 pie fr squared. [Please login or register to view this link] and inductance [Please login or register to view this link]
Metal mounts use the actual ground plane. Car, little pipe , etc..
Use some type of base ( search antron up/down ratio ) to bring your 102 in line.
