Grounding Question
- Pontiac787
Grounding Question
I want to add a ground wire to my antenna bracket. It is mounted on the bedrail of a pickup truck on top of the bed liner. Do I want to run a wire from the bracket to the frame then from the frame to the bed or would it be better to run a wire from the bracket to the bed, then from the bed to the frame?
- Circuit Breaker
- Handle: Circuit Breaker
- Real Name: Stephen
- Call Sign: K7CB
- Antenna: OCF Dipole
- Radio: HR2510/Yaesu FT-950
i would make sure the antenna bracket has a good connection to the bed. Then make sure the bed has a good connection to the frame. After that, maybe make sure the cab has a good connection to the frame. That should cover it.
Yaesu FT-950
Yaesu FT-8100
Uniden Washington Base
Uniden HR-2510
Icom ID-92 HT
SteppIR 40-6M Yagi
OCF 75/80M dipole
Antron 99
Yaesu FT-8100
Uniden HR-2510
Icom ID-92 HT
SteppIR 40-6M Yagi
OCF 75/80M dipole
Antron 99
