maco v58
- steve32
- Real Name: steve coope
maco v58
Hi this is my first post so hi to everybody I have just had one of these antennas sent to me by my brother who now lives in the US what i would like to now is in the manual says you need to mount it on 1.1/4 mast but as my mast is a 12 ft by 1.5 as its on the chimney stack and im up om hill that gets a lot of wind i dont wont to get anything thiner so my questune is is there a way of mounting this on my mast thanks regards steve
- Red Warrior
- Radio: Galaxy 959
If the antenna has not yet been assembled, take the flange on the bottom and test fit it over the 1 1/2 inch pipe. I put mine on 1 1/2 inch steel pipe and it fits. Once you get the flange over the pipe, drill two holes through the flange and pipe and insert two bolts through the holes. Remove the flange and assemble the antenna then reinstall the flange over the pipe and reinstall the bolts.
If the 1 1/2 inch pipe is too big, build/buy a reducer to take the size down to 1 1/4 inch and repeat the process above.
