will this antena work?
Twink
Real Name: Reno
Radio: Cobra148F/Cobra 200
#221272
Post by Twink »
would this antenna work? i'm trying to put up an antenna at my apartment, but they won't allow any antennas/// i figure i could "hide" this one up there...
Dammit Wrongway! I drilled the freaking hole!
[ external image ]
pro785
#221308
Post by pro785 »
Yes it will work just make sure you check your swr's.
treetall
Handle: treetall
Real Name: Carrington
Radio: Galaxy
Post by treetall »
yep itll work. let me know what ya think about it if you get it. what kind of radio you gonna run with it? its basically a 40 dollar dipole that u could build for maybe 5 or 10 bucks. hahahaha
801 working this baby driver in the carolinas getting out the way.
Night Crawler
Post by Night Crawler »
Twink
Real Name: Reno
Post by Twink »
can someone throw me a link of how to make a good dipole that is stealthy and cheap, and still works good? and can handle 500w
[ external image ]
Circuit Breaker
Handle: Circuit Breaker
Real Name: Stephen
Call Sign: K7CB
Antenna: OCF Dipole
Radio: HR2510/Yaesu FT-950
Post by Circuit Breaker »
Twink wrote:would this antenna work? i'm trying to put up an antenna at my apartment, but they won't allow any antennas/// i figure i could "hide" this one up there...
Yes, it will work. Just keep in mind that being a horizontal dipole you'll only be transmitting two directions, which will limit your contacts. Then, you also have to consider that the dipole (being horizontal) will have a 20db attenuation due to cross polarization since most other operators will be vertically polarized. This will make little difference during skip openings though.
Yaesu FT-950
Yaesu FT-8100
Uniden Washington Base
Uniden HR-2510
Icom ID-92 HT
SteppIR 40-6M Yagi
OCF 75/80M dipole
Antron 99
