using a wilson 1000 as a base?
Twink
Real Name: Reno
Radio: Cobra148F/Cobra 200
#221271
Post by Twink »
redman cb shop has a ground plane for a wilson 1000. could i use this to make my wilson 1000 into a decent base antenna?
Dammit Wrongway! I drilled the freaking hole!
[ external image ]
Night Crawler
Post by Night Crawler »
Twink wrote:redman cb shop has a ground plane for a wilson 1000. could i use this to make my wilson 1000 into a decent base antenna?
No
Circuit Breaker
Handle: Circuit Breaker
Real Name: Stephen
Call Sign: K7CB
Antenna: OCF Dipole
Radio: HR2510/Yaesu FT-950
Post by Circuit Breaker »
Assuming the "radials" are long enough, it will load up and work as a base antenna...and it might work okay if it were up high. But any base CB antenna will outperform it.
Yaesu FT-950
Yaesu FT-8100
Uniden Washington Base
Uniden HR-2510
Icom ID-92 HT
SteppIR 40-6M Yagi
OCF 75/80M dipole
Antron 99
Night Crawler
They're not
Irondog
Real Name: Rick Haven
Antenna: Dipole
Radio: Cobra 142GTL, 949DX
Post by Irondog »
I think that's the whole idea of a ground plane. The Wilson 1000 uses the vehicle as the ground plane. In order to use a mobile antenna....that's what you have to do...build a ground plane. I can't remember which sponsor....but I know one of them sells a ground plane specifically designed for turning a mobile antenna into a base. Browse their sites and you'll find it. You'd be better off making a wire dipole.....you can mount it anywhere, inside or out....or a regular base antenna. I'm using a wire dipole.....and believe this.......hanging from the ceiling fan in my room. :icon_e_surprised: ...and it gets out I know for a fact at least 10 miles as the crow flies. I'm sure I get out farther because mys sis told me I was hitting her in the red. The best thing is that I used old stuff I had lying around to build it with and I was only out the cost of the coax.
Sorry I got a bit off topic...but it felt relevant. :biggrin:
"Dream yourself into the real world and leave the illusion behind."
Once a Marine, Always a Marine.
#221415
Post by 'Doc »
If that groundplane thingy works as it should, then it will make that mobile antenna work, be usable. That won't make it work as well as a larger 'base' antenna, but it ought to be at least usable. If you've got 'limits', and if that set up falls 'inside' those limits, then it's one option. There are other options. Find, then select the option that works out best for your situation. (Good 'trick' when you can do it with just one 'try'.)
