Wilson roof mount Pred 10k????
wrong way
Real Name: Ryan
Radio: gl and 98vhp
#211880
Post by wrong way »
:?: my 10k is on the way to the house from clays radio shop I just got the antenna I gotta make it work with the wilson roof mount (with the coax going into the star washer) I know it will screw right on but strenght will be an issue was thinking about drilling a hole through a 8" by 12" thin piece of alluminum and putting it against the roof (under side) and using that to strengthen my roof. will this allow for the star washer to get a good enough ground? I plan on grinding to bare metal.. thanks Wrong Way
lonesome 500
#211883
Post by lonesome 500 »
that.....or 7.5'' circular saw blade.........
better to ground and firm up.......than take a chance
<center>
<a><img></a>
</center>
wrong way
Real Name: Ryan
Radio: gl and 98vhp
Post by wrong way »
lonesome 500 wrote:that.....or 7.5'' circular saw blade.........
good suggestion thanks
Handle: Jesse James Dallas
Real Name: Jesse
Radio: working
Post by jessejamesdallas »
[ external image ]
Thought I had the Patent on this trick! :lol:
the_junkie
#211901
Post by the_junkie »
jessejamesdallas wrote:[ external image ]
just gotta ask...what kind of mount is that? seriously...like, the mount, not the saw blade.
Real Name: Jesse
Radio: working
[ external image ]
It's a older roof-mount Predator...(no longer made)...I had to drill out the center hole of the saw blade so the thing would fit, and then because of the slop of the roof, I ended up having to add a couple extra bolts to stabilize everything...
lucky7
Post by lucky7 »
The wilson roof mount is diffrent than the mount for the 10K. The 10K use's a stud mount and the wilson roof mount use something similar to a so239 connector. You are going to have to get a puck mount or atleast a behive style stud mount.
