K40 Trunk Lip Mount Antenna
- redneck330
- Real Name: Ronnie
- Antenna: Wilson 5000
- Radio: Galaxy 88 HL
I have a K40 Trunk Lip Mount Antenna on my wife's car with a Connex 3300HP but I cannot get the SWR below 2.5. I had this antenna on truck but went back "OLD SCHOOL" with a 102" whip. The SWR with that antenna and same radio ran between 1.1 to 1.6. This has me confused. Any suggestions?
- drdx
- Handle: dollar-98
- Real Name: David
- Antenna: Many
- Radio: Many-
Does the mount have a good ground connection? Is it lower on either end of the band, like maybe it needs to be shortened? If it is higher on 40 than on 1, it is too long. If it is lower on 40, it is too short. On the ground connection, make sure you scrape a little paint away and when you're done, if you have one, probe the mount to the body and make sure it has a good connection, with an ohm meter. -drdx
- redneck330
- Real Name: Ronnie
- rongstad
- redneck330
- Real Name: Ronnie
- rongstad
X2 with drdx.........I'd check the ground, especially where the allen screws clamp down on the trunk lip.drdx wrote:Does the mount have a good ground connection? Is it lower on either end of the band, like maybe it needs to be shortened? If it is higher on 40 than on 1, it is too long. If it is lower on 40, it is too short. On the ground connection, make sure you scrape a little paint away and when you're done, if you have one, probe the mount to the body and make sure it has a good connection, with an ohm meter. -drdx
- redneck330
- Real Name: Ronnie
No antenna is going to present the same SWR, or other characteristics when moved from one place to another. Unless those 'places' are exactly alike, sort of. So, adjusting/tuning an antenna is a "given". If you don't have to do that you are just very lucky (buy me a lottery ticket!).
It's a good idea to make sure your antenna is getting/making good contact with the car's body. That is the other half of that antenna, you know. There are exceptions to that but you don't have one of them.
[There seems to be a preoccupation with 'grounding' lately. It is important, but it's far from being the 'answer' to most antenna problems.]
It's also nice to have one'a them antenna analyzers! The 'catch' to that is that they are not cheap. If you don't do a lot of antenna changing, it's sort of over-kill. Know someone who has one? Borrow it! They are also not 'plug-n-play', so borrow that instruction manual too. Some times the owners of those thingys are open to bribes to do all that stuff for you, (mine is beer)...
- shadow
- Radio: Cobra 25 NW, 148 GTL
- super20dan
