best moblie radio for ssb?
Whether you're new to using single sideband (SSB) or have years of experience, this forum is the perfect place to ask your questions or provide assistance to those who are new.
- DX47
- Handle: 316
- Real Name: Skylar
- Antenna: Wilson 5K
- Radio: RCI 2950 and IC-7000
Post by SkinnyPuppy »
Agreed on the 2970. I have one (I have a second one ordered) and it is very easy to tune this radio to whatever frequency that you want.
- DX47
- Handle: 316
- Real Name: Skylar
- Handle: 316
- Real Name: Skylar
Modified Ham rigs (eg, Icom, Kenwood, Yaesu) are often best for SSB, but most of them drag **Censored** on AM... Icoms are often
passable. I've also heard the little Alinco DX70T has quite a bit of punch on AM as well.
One main gripe about HF rigs is aside from the mediocre AM, the noise blanker circuits often leave something to be desired, even
on SSB. There aren't that many HF rigs out there with a noise blanker that is any good... A lot of CB's have better noise
blankers! (eg, ones that cut out the noise without distorting the signal badly).
I would say it depends on how much you're going to use AM vs SSB... if you are on SSB 90% of the time, find an HF rig that
has at least passable AM for those times you need it. When I ran my Icom 706MKII I had no trouble getting around locally on
AM if I needed to, still plenty of audio. (esp with the compressor on).
I realize they are expensive, but some deals can be had here and there. It is hard to beat them for stability once they're warmed
up. Most of them also do 100W out the back which eliminates the need for an amp for most basic SSB operations. (Although I certainly
liked having 650 watts on tap when I needed it.... made working DX a lot easier.
On the other hand if you are 50/50 AM SSB I would choose something like a 2950DX, 2970DX, or a decent HR2510 or HR2600 (w/chipswitch) if
you can find one that hasn't been mucked around with too badly.
Modified Grant XL/148GTLs also make decent SSB rigs, if the mod is done right and you have some sort of frequency
counter. Problem is most of the MB8719 mods out there are scatterbrained affairs and not as elegant of a set up as something
like a 10M conversion. (eg, 2950, etc).
Whatever you do, if you like SSB, stay away from the old galaxy rigs (eg, saturn, 88HL, 99V) etc. I know the newer rigs are a
lot better, but the older rigs were drift-o-matic and unuseable for anything more than very short, random SSB ops. The frequency would
drift too much. I had once test my Saturn base, I had it on all day then tuned it up on SSB, got everyone on freq, then I went out and
got a cup of coffee across town and by the time I got back home the radio had drifted 800 hz! (and in SSB terms, anything more than 10-30 hz
here and there is noticeable... so 800 is like off the charts!) (the other guys were running HF rigs and I know they hadn't moved on
me...)
-Mike
me...)
-Mike
- nighttrain
- Real Name: Tommy
- Radio: Galaxy 919
Post by nighttrain »
I guess I need to take my 949 to the shop, and have it tuned properly.For a CB radio, you really can't beat the 148/grant radio's. They will drift a touch in cold weather, but what do you expect from a reference crystal? The 959/949 radios do OK as well. They drift more, but once warmed up do fine. The key for them is in the tune. It's really easy to get too carried away with the alc and then they are hard to listen to.
- MOONSHINER
- bookie
i used an Icom 750pro for a mobile untill someone else thought it would look better in there mobile or in a pawn shop. the punk probably didnt even know how to turn the radio on. it worked great on AM and even better on SSB. it was the best radio i have ever had and nothing comes close. once the software was fixed. thats my .02. but knowing that most people do not wish to spend that kind of money on a mobile the RCI is a good radio, the magnum is another cheaper option if you still want a good AM radio also.
nate
nate
Post by RUDEBOY292 »
I still have my Cobra 138XLR that I got new in 1978 and I had used it as a base radio .I talked on a Starduster base antenna and talked all over the country on that radio. A D-104 was wired up to it and she sounded sweet all around town. Now I have a RCI-2995 BASE that I am going to run as soon as I get back stateside and put up the antenna.
Post by N.T.M. mak »
well i'm using a superstar 360fm which is basically a cobra 148gtldx. excellent on ssb it kicks out about 30watts standard. added features are kc shift and splits. cant knock it. at home i have a 30 year old president madison which is a great rig. the old ones are the best you nor 73's 51's from the uk
- Handle: Possum
- Real Name: Perry
- Antenna: Imax 2000 Maco 4 vertical
- Radio: Cobra 148gtl
- KI4MSJ
- Handle: Barnstormer
- Real Name: SCOTT
- Radio: ICOM 7000
- Mentor3006
- Handle: Mentor / Space City 3006
- Real Name: Dave
- Antenna: Realistic stainless steel 102
- Radio: President McKinley II FCC
Post by Mentor3006 »
One thing I did notice, was that all of the rigs mentioned were BIG... Especially in newer vehicles, mounting a large radio is a pain in the tail.
For a smaller footprint radio, the Radio Shack TRC-465 / Uniden PC-122 when equipped with a power mic, have GREAT audio, and shoot skip with the best of them.
I have these radios, and have had 148 GTLs and their clones for decades. I stuck with the TRC-465 due to its size, and the reports from my QSLs that say I sound cleaner on the TRC than on my old 148...
I know it's an odd radio, and Radio Shack stuff will never get any respect, but the things simply work. And I don't care for brand names, just what works well for me!
- North Texas Mudduck
Re: best moblie radio for ssb?
Post by North Texas Mudduck »
i have done some of my own testing here for awhile
been listening to the 35 thru 40 usb and lsb
anytime i heard a radio that had a scratchy sound or buzzing or choppy sound i would say hey thats a great sounding radio what kind is it
and 9 Times out of 10 it was some kind of export
i heard a few talking on the Galaxy979 and the magnum45 heard a few 99v and thats just tipping the iceberg
those things sounded like dew dew
i heard a uniden 122 with a studio mic and that thing was sweet sounding
good tone smooth sounding easy to listen to
did hear some really nice stations using the 2510 the 2950s the 2970 and the 2970N2
did hear a bunch of the hf rigs talking and quite frankly i like the way the 2970 and 2510 sounded
so IMO if you are going to talk SSB more than AM then get a radio that was actualy built for SSB
so if it was a echo board already built into the radio then i wont use it for SSB
so down to the nut cutting
if i could find a 2510 not all gutted for every last watt
next would be the 2970n2
i just may go get a 2970n2 in the next week and try it on my end
Post by 231 »
Cobra 148GTL either Philly or Taiwan mademudder wrote:what moblie radio do you think is the best one for side band?
Uniden Grant either Philly or Taiwan made
Cobra 2000 same as above.
SBE's (most of them)
There are a few others I've enjoyed, but the receiver and transmit on the above are very good.
For exports (and there are darned few)
RCI 2950
Uniden 2510
257 Magnum properly tuned
I've got a new Uniden 980SSB coming....I'll let you know how I like it. I'm excited to try it even though I'm stuck with just the regular frequencies.
231
- 108dt206
- Handle: Countryman
- Real Name: barry
- Call Sign: Mm6iur
- Radio: NATO 2000
Jump to
- Welcome and Community
- Skip Shooter's Paradise
- ↳ General Discussions
- ↳ Watergates & Videogates
- ↳ Shooting Skip
- ↳ Hall Of Fame
- ↳ Journal
- Radio Help
- ↳ Intro To Radios 101
- ↳ General Questions
- ↳ Base Setups
- ↳ Competition Rigs
- ↳ Charging System
- ↳ Mobile Setups
- ↳ Antenna Help
- ↳ Microphone Info
- ↳ Radio Modifications
- ↳ Sideband (SSB)
- ↳ Tube Radio Equipment
- ↳ Other Technical Questions
- ↳ Miscellaneous Radio
- Buy / Sell / Trade
- ↳ For Sale Area Rules
- ↳ For Sale Area
- ↳ eBay Shopping
- ↳ Amazon Shopping
- ↳ Trade Equipment
- ↳ Wanted Radio Equipment
- ↳ Positive Feedback
- Off Topic
- ↳ Miscellaneous Chat
- ↳ Computer Help
- ↳ Signature Test Area
- The White House
- ↳ Ask Marv
- Home
- All times are UTC-06:00
- Cookie-Settings
- Delete cookies
- About us
- Downloads
- Contact us
