Title 95.410 How much power may I use?
This is a place to read about the rules and regulations set down by the Federal Communications Commission (FCC) regarding CB Radio.
Locked
Phaze91460
#51990
Post by Phaze91460 »
Code: Select all
[Title 47, Volume 5]
[CITE: 47CFR95.410]
[Page 530]
                       TITLE 47--TELECOMMUNICATION
                         COMMISSION (CONTINUED)
               Subpart D_Citizens Band (CB) Radio Service
Sec. 95.410  (CB Rule 10) How much power may I use?
    (a) Your CB station transmitter power output must not exceed the
following values under any conditions:
    AM (A3)--4 watts (carrier power) SSB--12 watts (peak envelope power)
    (b) If you need more information about the power rule, see the
technical rules in subpart E of part 95.
    (c) Use of a transmitter which has carrier or peak envelope power in
excess of that authorized voids your authority to operate the station.
Locked
