Simple to construct CB antenna with 9dBi of Gain
KOA4705
Handle: 555
Real Name: Joe
Radio: tram titan
#412404
Post by KOA4705 »
Inexpensive antenna to construct with low angle radiation for DX and ground wave. Use 9 feet of 300 ohm transmission line from the antenna feed point
to the SO239 connector.
KOA4705
Handle: 555
Real Name: Joe
Radio: tram titan
Post by KOA4705 »
KOA4705
Handle: 555
Real Name: Joe
Radio: tram titan
Post by KOA4705 »
De_Wildfire
Handle: De_Wildfire
Real Name: Greg
Post by De_Wildfire »
KOA4605
That sounds great! Can you run the numbers on the resonate frequency of 28.4 MHz ? See if there is a nice overlap into 27 mhz and see how the SWR''S stretch out to 26.965? Thanks.
KOA4705
Handle: 555
Real Name: Joe
Radio: tram titan
Post by KOA4705 »
+/- 500Khz from the new resonant frequency will be 2:1 SWR
De_Wildfire
Handle: De_Wildfire
Real Name: Greg
Thanks, KOA
