Simple to construct CB antenna with 9dBi of Gain
- KOA4705
- Handle: 555
- Real Name: Joe
- Radio: tram titan
Inexpensive antenna to construct with low angle radiation for DX and ground wave. Use 9 feet of 300 ohm transmission line from the antenna feed point
to the SO239 connector.
- KOA4705
- Handle: 555
- Real Name: Joe
- Radio: tram titan
- KOA4705
- Handle: 555
- Real Name: Joe
- Radio: tram titan
De_Wildfire Verified
- Handle: De_Wildfire
- Real Name: Greg
KOA4605
That sounds great! Can you run the numbers on the resonate frequency of 28.4 MHz ? See if there is a nice overlap into 27 mhz and see how the SWR''S stretch out to 26.965? Thanks.
- KOA4705
- Handle: 555
- Real Name: Joe
- Radio: tram titan
+/- 500Khz from the new resonant frequency will be 2:1 SWR
- Real Name: Greg
