SWR adjustments
SWR adjustments
#412165
Hey guys and gals,
I am curious to know what everyone is using these days to set the SWR (standing wave ratio) on your antennas?
I have used several different pieces of equipment, back in the day I had a "Dip Grid Meter" , Heathkit brand that I built along with a Heathkit Watt Meter. I later graduated up to a popular SWR/Watt meter. Over the years I got a MFJ model 259/269 antenna analyzer which was the "cats meow" then, borrowed not to long ago a couple different "RigExpert" analyzers but to me the cost was outrageous.
Now I am using a pair of NanoVNA's, one has SMA connectors, the other has SO-239's. I use two as sometimes one reads slightly different so I compare and equal out the readings. These to me are the most cost effective but do require a learning curve and you can save the information if hook up to a computer.
What are you using?
295 antenna
Handle: 2950 or 295
Real Name: Charles Reney
Antenna: patriot, Discone
Radio: Stryker 955 , Browning Mark iv
Post by 295 antenna »
I use 2 things, first is the SARK100 Antenna analyzer and when everything is put inline then the MFJ-870 peak reading swr/watt meter
De_Wildfire
Handle: De_Wildfire
Real Name: Greg
Antenna: Imax 2000. Hex Beam, G5RV dipole, Jpole(UHF/VHF) Austin Suburban Tri Band (UHF/VHF)
Radio: Washington, Tram D201, Tram D64, Robyn 520D, Cobra 139XLR, Elecraft K3S, Kenwood 590S, Yaesu FTM 400DR, Alinco DR-235, ADI-146
Post by De_Wildfire »
I use an old MFJ-259 and and a couple Autek Research WM-1computing meters. I am thinking of upgrading to the Comet CAA-500.Which gives me the best of both worlds.
