hello, I'm trying to repair a galaxy saturn base that someone has screwed up bad, there is a black ground wire coming from point "41" on the slide switch board and I cannot find where its supposed to go from there, the only available schematic is vague with no legend on the tie points,
this wire grounds the frequency readout board, hopefully someone has the same radio and can point out the correct place this wire is connected to, chassis ground will work for this wire but I know that's not the correct spot, and if I tie it to other grounds I get counter noise, thanks in advance, hope this isn't to confusing of a question..
Message from moderator Bozo
replaced place with black
per
jerseyoutlaw wrote:
small correction on my post, it should say " Black" wire, not "place" trouble typing this morning...
@jerseyoutlaw
