Stryker 955 no output on am
- Matt1987
- Handle: Rocketman
- Real Name: Matt
I have a 955 I acquired for this problem unit will transmit on SSB but has no output on AM never owned or operated a Stryker didn’t know if I was missing something or where to look any help be greatly appreciated this is a lot different than galaxy radios not up to par on the surface mount radios
No AM modulation usually means the AM voltage regulator is burned out. I think on that radio it is located on the right side toward the back looking down in the radio with the component side lid removed radio face toward you.
- Matt1987
- Handle: Rocketman
- Real Name: Matt
Ok thanks I can check that an has full power on SSB 100 watts or so and nothing on Am guess should made that more clear when posted
