Stryker 955 no output on am
Matt1987
Handle: Rocketman
Real Name: Matt
#410115
Post by Matt1987 »
I have a 955 I acquired for this problem unit will transmit on SSB but has no output on AM never owned or operated a Stryker didn’t know if I was missing something or where to look any help be greatly appreciated this is a lot different than galaxy radios not up to par on the surface mount radios
No AM modulation usually means the AM voltage regulator is burned out. I think on that radio it is located on the right side toward the back looking down in the radio with the component side lid removed radio face toward you.
Matt1987
Handle: Rocketman
Real Name: Matt
Post by Matt1987 »
Ok thanks I can check that an has full power on SSB 100 watts or so and nothing on Am guess should made that more clear when posted
