1) I have read that the golden eagle 150 is for a linear antenna. Is the golden eagle 150 worth using on my set up? 2) using the SWR meter I purchased and following the instructions to test my antenna tx and reception, I get the same readings for receiving and transmitting of 1.1, is that possible? Shouldn’t the readings be a little different?
3) I live in San Diego and at least truckers use CB. I live less than 1/2 mile from a freeway and live on a hill and my antenna is 20 feet above my roof top to the tip of my antenna. Shouldn’t I receive some squawk or at least faint transmissions? My receiver only shows slight movement where I guess it shows some sort of received transmission but I don’t hear anything. I opened my receiver and verified there is a speaker inside. Any ideas? I guess that would be 4 questions
