Antenna
gsh82962
Handle: Landlord
Real Name: Gary
Antenna: Maco
Radio: Kenwood
Antenna
#409859
Post by gsh82962 »
Looking to find out if anyone on here has put a Mako 5/8 ground plane above an aluminum flat side beam wonder if there's any interference thank you so much
443 Arizona
Mod Duck
Mod Duck
Handle: Double R
Real Name: Steve
Radio: madison on 5/8 wave
Post by 443 Arizona »
interesting question and I have seen that exacct array before, I assume there is an effect but negligable??? hmmm well i would not put them close together,, in fact, a 1/4 wavelength would possibly be a gain,
I think the ground plane of the Maco would interfere with the beam as messing with its directional ability and probably tuning. A antenna with no ground plane would be better.
De_Wildfire
Handle: De_Wildfire
Real Name: Greg
Post by De_Wildfire »
I would not put them together. When I put up my Hex Beam, it was a few feet from a wire dipole and it caused the Beam to have a higher SWR when I turned the beam into the direction of the wire. The radiation pattern can be changed on the beam. When I had my attic antennas too closer together on VHF, I noticed the pattern on one of the antennas changed. Try to relocate the vertical.
Bozo
Handle: Bozo The Clown
Real Name: James
Antenna: Monkey Made MM9
Radio: General Lee Radio
Post by Bozo »
When it comes to antenna installations, having metallic objects like aluminum flat side beams can interfere with the antenna's performance. Metals can reflect, refract, or absorb radio waves, resulting in weaker signals or changes in radiation patterns.
If you're considering placing a Mako 5/8 ground plane antenna above an aluminum flat side beam, it may introduce interference. The aluminum beam can reflect signals or block them partially, leading to reduced performance or altered radiation patterns.
Ideally, mount the antenna in a location with a clear line of sight and minimal metallic obstructions. However, the impact of interference can vary based on installation specifics, the proximity of the antenna to the aluminum beam, and the frequencies involved.
For accurate guidance, consult experienced antenna installers or amateur radio enthusiasts familiar with such setups. They can offer personalized advice and suggest alternative mounting options to minimize interference.
Remember to refer to manufacturer guidelines or seek expert advice for optimal antenna placement and performance.
Donate here
