Can’t get swr down on Channel 40
- bloggerstomper
- Handle: bloggerstomper
- Real Name: Rafa
Boy am I in a pickle. I went ahead and installed my uniden 520xl on my truck.
This wasn’t a small feat. I had to desolder the faceplate from the body and solder it via wires to the body.
Once that stupid feat of stupidity was finalized, I installed it in its hopefully permanent home, and proceeded to try and tune it. I got a too loaded firestik antenna with the tunable tip on it, and I just can’t get the swr below 3 on channel 40.
Channel 1 is at 1, but I can’t get the antenna any shorter!
Do I have a bad antenna ground? Are the swr gods smiting me for my insolence?
Any help would be appreciated!
jessejamesdallas Verified
What kind of truck, and where are you mounting the antennas?
If it were me...I would just go with one antenna...allot less headache tunning.
- bloggerstomper
- Real Name: Rafa
Thank you for your reply!
It’s a toyota tacoma. And I’m only using one antenna. It’s on a beacket in between the cab and the bed
Bozo Verified
- Handle: Bozo The Clown
- Real Name: James
- Antenna: Monkey Made MM9
- Radio: General Lee Radio
Well said @jessejamesdallas! One antenna is better in this case.
Hello @bloggerstomper
I had the same issue with my Chevy Silverado and I tried to mount the antenna off the truck bed above the cab. I ended up having to drilling a hole in my cab to get the SWRs down. You can see in the low image where I tried to mount it just behind the cab, but there just wasn't enough reflect. Need that ground plane!!!
jessejamesdallas wrote: December 21st, 2022, 6:16 pm What kind of truck, and where are you mounting the antennas?
maybe the choice of antennas, or maybe your mount isn't grounded enough...(I'm leaning towards it being the antenna just picking up too much reflect or just not a tall enough antenna)bloggerstomper wrote: December 21st, 2022, 7:37 pm Thank you for your reply!
Here's my Tacoma with a Monkey Made "Big John" antenna...SWR 1.0-1.1 across the band.
Same truck, only with a Predator 10K...SWR still 1.0 to 1.1
- bloggerstomper
- Real Name: Rafa
Thank you @jessejamesdallas and @Bozo
I have a top loaded firestick antenna.
I think I’m going to dig deeper to get some better reception!
Bozo Verified
- Real Name: James
@bloggerstomperbloggerstomper wrote: December 22nd, 2022, 8:50 pm Thank you @jessejamesdallas and @Bozo
You're welcome
- bloggerstomper
- Real Name: Rafa
@Bozo also, I would love to see more about your antenna mount’ where/how did you get that?
Bozo Verified
- Real Name: James
It's called a stargun antenna made by Troy tullos. I don't think he's still making them.bloggerstomper wrote: December 22nd, 2022, 9:31 pm @Bozo also, I would love to see more about your antenna mount’ where/how did you get that?
Now I'm using monkeymade antenna. Made by Mike.
Fun fact. I built both their websites. Neither website is still up though. I think
- bloggerstomper
- Real Name: Rafa
Oh!Bozo wrote: December 22nd, 2022, 9:36 pmIt's called a stargun antenna made by Troy tullos. I don't think he's still making them.bloggerstomper wrote: December 22nd, 2022, 9:31 pm @Bozo also, I would love to see more about your antenna mount’ where/how did you get that?
Fun fact. I built both their websites. Neither website is still up though. I think![]()
I meant the mount on the tacoma that extends behind the cab
Bozo Verified
- Real Name: James
The Tacoma is @jessejamesdallas ride. Jesse does look like a clown also so I can understand how you got us confused with each other.
Mine is the Silverado. Mount on mine was costum job by Troy.
- bloggerstomper
- Real Name: Rafa
Oooops! Too many wobbly popsBozo wrote: December 22nd, 2022, 9:53 pm The Tacoma is @jessejamesdallas ride. Jesse does look like a clown also so I can understand how you got us confused with each other.
Question stands tho!
The issue is a capacitance problem because of location. It probably could be solved by bringing the mount closer to the cab height like you see in Jesse’s Tacoma pics. If this can’t be done then try a quality center loaded antenna like Jesse’s or similar, say a hustler 27q, Amazon has them.
@Bozo, I wish Troy was still around, he made some of the weirdest looking antennas I’ve ever saw and most of them actually worked well.
Troy Built were Tinker-Toy antennas...least thats what they looked like!
Post Merge Complete
Added 17 hours 23 minutes 20 seconds after previous.
Originally I had the coax running in the middle of the tube, but last time I replaced the coax I got lazy and just used some plastic tie straps to hold it down.
Built this about 4 or 5 years ago, and been using it ever since with no problems...I didn't want to drill holes in the roof on this truck, which is why I went with this...It puts the antenna "roof-high" so there's no reflect from the cab.
Post Merge Complete
It's just some scrap 1" square tubing and cut up pieces of angle iron I had lying around the house I made the riser out of...(you can get it at Home Depot)bloggerstomper wrote: December 22nd, 2022, 9:51 pmOh!Bozo wrote: December 22nd, 2022, 9:36 pmIt's called a stargun antenna made by Troy tullos. I don't think he's still making them.bloggerstomper wrote: December 22nd, 2022, 9:31 pm @Bozo also, I would love to see more about your antenna mount’ where/how did you get that?
- bloggerstomper
- Real Name: Rafa
Now it’s doing this fun thing!
most likely that problem has to do with dissecting the radio and reassembling it to install it like you wanted...
high swr won't cause a radio to do what yours is doing...something didn't go back together right.
Bozo Verified
- Real Name: James
Looks like the radio is possessed. LoL
Merry Christmas
Merry Christmas
- bloggerstomper
- Real Name: Rafa
Yeah…jessejamesdallas wrote: December 25th, 2022, 8:24 pmmost likely that problem has to do with dissecting the radio and reassembling it to install it like you wanted...
It’s a Christmas miracle! Not…
Oh well… back to the drawing board
