I have a new in the box cobra 29 XLR.. I went to play with it the other night.. lights up as pretty as can be, but has to transmit or recieve.. I know it's a 40 year old radio.. but it's also new.. there's no visual cap leakage. But I figured that was the problem.. is there a section I should start replacing that caps at that may bring it back to life?.. thanks in advance!
Cobra 29 XLR No Tx or Rx...
- RedBaron324
- Handle: Red Baron
- Real Name: Michael
- Call Sign: 324
- Antenna: Maco 3 element beam, Sirio New Tornado 27
- Radio: Excalibur SSB
First thing I would look at on the pcb is corrosion from the solder acid and cold solder joints. Might try a different mic too!
