PRESIDENT fm cb radios
trx680
Handle: none
Real Name: Brian
Radio: CB radio
#409619
Post by trx680 »
So President is the only one making CBs with FM.
Anyone come across any CB shops that are TUNING these President radio?
Anyone here used one of their FM radios?
Windwalker
Handle: Windwalker
Real Name: Clifford Stewart
Call Sign: KD8QHS
Antenna: K-40// Hustler MagMnt
Radio: Cherida S890
Post by Windwalker »
Hi trx680
The new President radios with FM are FCC approved !
Any radio shop should be able to tune it up.
There are a couple older model radios out there that have FM !!
Just look around on Ebay and you will see them although I couldnt tell you the name or model of them !!
WW1
It’s funny, Cobra was the one started a petition to the FCC for FM acceptance and they don’t have a radio out yet. There are only a few radio’s but give it time FM will catch on. Now FM is a completely different mode, you will be able to mod it for that nice warm soft modulation but the radios won’t swing wattage like AM.
Handle: Jesse James Dallas
Real Name: Jesse
Radio: working
Post by jessejamesdallas »
trx680 wrote: November 17th, 2022, 4:09 pm So President is the only one making CBs with FM.
Don't waste your money having some shop "tune" one of the President radios...There's really nothing that needs to be done to one right out of the box, other than opening up the modulation to 100% and maybe adjusting the SSB output a little...
On the President McKinley the AMC pot is easy to find for opening up the modulation...just hook up a power meter and turn it till it peaks...if you turn it too far all that happens is the modulation drops back down (there's no stopping point which is why you need a power meter to watch)....
The SSB output pot is pretty close to the AMC...just turn the ALC pot like you did the AMC for modulation, only watch your power meter and don't go much more than 12 watts for SSB...It can go as high as 20+ watts, but you won't sound that good on ssb that high...
Here's a link to CB Magazine doing a tune-up on the McKinley...adjustments to the pots start around 25:00 into the video.
I did this with my President McKinley several years ago, and get more complements with the set-up, than with any other radio I have ever had...I have mine hooked up with a 1x2 amp for more power, so I'm seeing around 400w out...Nothing else done to the radio...opened up the modulation from 75% (factory set) to 100%, and SSB set to 12w.
Lost Ram
Handle: Lost Ram
Real Name: Kerry
Antenna: 570' Loop with 600 ohm open feed line
Radio: Yaesu FTDX 101 MP / TRC-450
Post by Lost Ram »
I hope the FCC turns Yaesu C4FM Mode loose on the HF ham bands, legally you can only use it on 10M and it sounds so good. Issue its more then 3kc's wide so its frowned upon use on other bands but, heck plenty of Hams with the audio gear additions are way more then 4-5 wide. This c4fm is digital mode on the FT-911(a) rigs.
CB: TRC-450, Imax
Thomas Jefferson.
Aughtry
Handle: Aughtry 722
Real Name: Ryan
Call Sign: K4TXN
Antenna: President Iowa
Radio: President Bill FCC
Post by Aughtry »
Old thread, but I haven't been here in a while! As an off-road vehicle sort, I can say that if your group is still using CB, or would like to revive it for off-road use, the President Bill II FCC with AM/FM is a nice little radio. About the size of 2 packs of cigarettes, and not much heavier, with a downward facing speaker can easily be mounted the the headliner. Paired with a President Iowa base loaded antenna that simply whips out of the way against any branch, it's a great fit. The new FM aspect makes it a much better option than older AM only CB's for short range group communications. I tell you this from experience.
That said...I also have 2 other radios in the truck for different frequencies. This little radio at a basic 40 channels and 4 watts is an impressive new CB for the off-road genre. I really like it.
Carry On!
Aughtry 7 double-deuce waivin' atcha from Prisontown, TX
President Bill II FCC AM/FM with President Iowa antenna
Yaesu FTM-400 with Larsen NMO2/70B antenna
Yaesu FT-891 with various antennas
Tex.Proud on IG
Amateur - K4TXN
GMRS - WQZF521
Mentor3006
Handle: Mentor / Space City 3006
Real Name: Dave
Antenna: Realistic stainless steel 102
Radio: President McKinley II FCC
Post by Mentor3006 »
So as of December 2023, I see being lazy and just searching ( edited by CBRT staff ) for AM / FM CB Radio models from some company called Radiooddity I have never heard of, Cobra, Uniden, and of course President. I believe it was Cobra and Uniden that were pushing the FCC to approve FM on the CB service. There is only one FCC approved AM / SSB / FM radio on the market right now that I am aware of though, and that is the President McKinley II FCC. I have wanted a President radio for years, and the AM / SSB / FM got me to jump....
Windwalker
Handle: Windwalker
Call Sign: KD8QHS
Radio: Cherida S890
What exactly did you jump at ??
dbhost wrote: December 9th, 2023, 12:41 pm So as of December 2023, I see being lazy and just searching Amazon for AM / FM CB Radio models from some company called Radiooddity I have never heard of, Cobra, Uniden, and of course President. I believe it was Cobra and Uniden that were pushing the FCC to approve FM on the CB service. There is only one FCC approved AM / SSB / FM radio on the market right now that I am aware of though, and that is the President McKinley II FCC. I have wanted a President radio for years, and the AM / SSB / FM got me to jump....
FM has been approved for a while but the manufacturer's are getting rid of old stock first so a lot of the dealers don't have them on the shelf. The conversion radios aren't type accepted but there is plenty of them that are FM ready.
The McKinley is a nice radio, think you will be happy with it.
Mentor3006
Real Name: Dave
I mentioned I think it was my introduce yourself thread, that I've had a Realistic TRC-465 (basically a Uniden PC122, not a bad radio at all, but it is quite long in the tooth and spent a few too many years in a Jeep with no top... I started this camper van build and with FM being a new thing, figured I would go for it. I kept holding out for Uniden to put out basically a Bearcat 980ssb with FM but nope... I never thought a President radio with premium features would be in my price range, but black friday deals on ( Edited by CBRT staff ) and I have it mounted up in my van now. I always drooled over President radios in years past, fantastic audio on them, and enough features to keep a teenager busy instead of a fidget toy...
295 antenna
Handle: 2950 or 295
Real Name: Charles Reney
Antenna: patriot, Discone
Radio: Stryker 955 , Browning Mark iv
Post by 295 antenna »
There are some fm clubs out there but I'm not hearing them. I'm checking though. Listen for 2950 on sideband. That's where I hang out
Mentor3006
Real Name: Dave
Still waiting on my coax to be deliered. Not like in the old days when I could run down to the local electronics parts house and get coax and ends off the shelf... No more Radio Shack, no more Electronic Parts Outlet, not even a Frys to go to... Bleh.
Windwalker
Handle: Windwalker
Call Sign: KD8QHS
Radio: Cherida S890
dbhost.
I have edited your posts.
WW1
Mentor3006
Real Name: Dave
Windwalker1,
It must have been the forum software changing text to links. I didn't think I was allowed to post links yet. Not intending to anyway... I will post the link to the radio when I reach the blessed post count...
I get it, I manage a woodworking forum and have to do this stuff too.
Windwalker
Handle: Windwalker
Call Sign: KD8QHS
Radio: Cherida S890
I understand
Thanx
WW1
295 antenna
Handle: 2950 or 295
I miss radio shack
