convert extension jack to line audio out help
- dss56
- Handle: THE DJ
- Real Name: Bob
- Radio: Kenwood 440st
Hi.
Looking to see if anyone has any suggestions to convert a cb radio extension speaker jack to a low level line out audio?
Just needs to be 1 channel as the ext jack is.
I need this for recording purposes as the regular audio is over powering and does not sound good so was hoping to try line audio level to see if that would help.
thanks
thanks
- dss56
- Handle: THE DJ
- Real Name: Bob
Thanks I have something that will bring audio down to rca level hope it will help some.MDYoungblood wrote: June 27th, 2022, 7:30 pm You could try a audio attenuator, you can check one out on Amazon.
- warlock35po
- Handle: Warlock35Po
- Real Name: Don
- Call Sign: VE1CSP
- Antenna: Beam and/2 wave Dipole
- Radio: Kenwood 570 D G
Hello,Iam curious as to how you are doing with the extension jack ,to Line audio out project? Regards warlock35po
- dss56
- Handle: THE DJ
- Real Name: Bob
Not too good still the ext audio from a cb radio is not line and looking to lower it to do some recording. I have tried resistors a Line attenuation and a few other components and the audio is not good. Ill be back at it soon to see if there is some other way.
I dont want to go in the radio and pick the line before the audio chip has to be from the ext jack on all cb radios.
thanks
thanks
- warlock35po
- Real Name: Don
- Call Sign: VE1CSP
Hello,Just a shot in the dark.Is it possible to run the audio through a computer Ap? I know NOTHING,about computers except how to get my mail and You Tube.Don't mean to waste your time.Regards.warlock35po
- dss56
- Handle: THE DJ
- Real Name: Bob
No this has to be right from the ext jack to the recorder board im working on. Just like the older watergate boxes.
- KP68
- Handle: KP68
- Real Name: Ken
- Antenna: Maco M105C Mr Coily 80meter sky loop
- Radio: Apache Labs ANAN 7000DLE MKii
I bought this last year and got good results. I can't quite remember how I had it wired at the input but I do remember for the output I used a Y cable, [2 male RCA to 1 male 1/8" TRS (stereo)]. The male 1/8" TRS plugged directly into the audio input jack of my computer. I used this Y adapter cable to ensure I did not get that annoying 1 ear only audio when listening through headphones. Don't quote me on this this but for the input wires, I think I tied the Right and Left POS wires together then tied the Right and Left NEG wires together. I do remember It worked fine. It's laying around here somewhere lol. If you want I'll find it and double check.
What radio are you using? The external speaker on most is only around 1W output, the PA on them is around 5W. Tapping into an equalizer should drop it down (audio) without sacrificing audio quality. You are saying the quality of the recording is bad, there might be another problem.
- dss56
- Handle: THE DJ
- Real Name: Bob
KP68
I did try something like that only it did not have the remote turnon.
It is a audio to line out and seemed not to do the job. My project is still i work in progress and hope soon to get some good results.
thanks for the reply dj56
Sounds like you are looking for something in a VOX (voice operated transmit) except you want it for receive.
