Siro 2016
GaRebel
Handle: GaRebel
Real Name: Bud
Siro 2016
#409430
Post by GaRebel »
Instead of using the little screws, if you used a brad would that work as good?
Handle: Jesse James Dallas
Real Name: Jesse
Radio: working
Post by jessejamesdallas »
as long as you can get a good tight-snug fit...screws can be tightened down so there's no movement...brads???
any movement can cause arcing, static, popping sounds, and loss of ground or positive contact...
GaRebel
Handle: GaRebel
Real Name: Bud
Post by GaRebel »
Tks for the info.
You could cut a slot in the tubing and use a quality ss hose clamp, but still install the screw to keep the tubing from telescoping into itself.
