2013 f-150 crew cab mobile rig install ideas
- Handle: Triple zero
- Real Name: Thomas
- Antenna: sirius tornado
- Radio: RCI-2995dxcf
Post by Bigbadwolfb4u »
Was thinking about maybe mounting to the front of the drivers seat which would be directly under my legs,but because of the electric seats and the rails for the seats is going to be a little tricky so it doesn't interfere with the seats back and forth motion( wife is short and seat has to be moved).
The truck has a sun roof so the cab ceiling is a little bit tight. The dash goes directly to the center console with the heat/air,and radio controls,so no room there either.
Also need to find an aestheticly good place to run the ant.coax instead of thru the window which I would not do anyway.
Thoughts? Maybe have it installed professionally?
Wish I would have taken some interior pics so everyone could see the layout of the interior,but could do that on a later post addition.
Any ideas would be appreciated.
Thanx, 3's
bbw
- Bozo
- Owner
- Handle: Bozo The Clown
- Real Name: James Wadsworth
- Antenna: Monkey Made MM9
- Radio: General Lee Radio
Re: 2013 f-150 crew cab mobile rig install ideas
I had a buddy that removed his entire glove box and mounted his radio, frequency counter, and is driver there. Regarding your coax. Most trucks have little holes behind seat that you can go out of and into the bed of the truck. That is how I ran my coax on my Chevy Silverado The amplifier can be put anywhere really, because there is only one position in my mind and that is the "On" position. LOL. I also had a remote that I ran from my toolbox to the front where I could control my amplifier...
Can you provide us with some images of your truck? You can upload them here https://postimages.org/ and it will give you the BBcode to put them on the forum.
- jessejamesdallas
President McKinley, with a 1x2 Hooper Amp in the back tool box...(the little red rocker switch just to the left of the cigarette lighter turns ON and OFF the amp)
- Real Name: Thomas
would be a serious pain and dangerous.
Did you have yours installed professionally?
Thanks
bbw
- Bozo
- Owner
@jessejamesdallas does all his own installs...Bigbadwolfb4u wrote: ↑November 16th, 2021, 5:14 pm I may consider buying a different radio,but also am thinking about the glove box which was mentioned in a past post, however having to lean across the seat to change the channel or work the clarifer on ssb
Thanks
bbw
Just make the passenger change channels for you?
- Real Name: Thomas
I'll figure it out,I really don't want to get rid of the radio as I've done too many mods to it,extra frequencies,unlocked clarifer , custom face,backlites etc .
- TNT1450
- Handle: Cobra Ball
- Real Name: Tom
- Radio: Pace 8046, Roadtalker 40's, Teaberry Stalker IX, GE 3-5814A
- Real Name: Thomas
Thank you for your reply and ideas in which if I do decide to go with the new radio I'm pretty much stuck with almost the same dilemma regarding the mounting as I don't think I even have room to do an in dash mount because there still isn't any room between the truck radio(am/fm),and the heat/air controller.
Btw,I had seen your post about the swr issue you were having with your own antenna,and wanted to ask if you had considered an antenna tuner to match your radio and antenna to get the lowest swr?
I have a mfj 949E tuner that I use with my base antenna that I am quite happy with because my antenna( Antron A-99) is mounted on a 40 ft tower which with the tuner eleminates having to climb the tower or pivoting the tower down to make adjustments.
The tuner was a bit expensive,but seriously made life a lot easier considering the options.
Take care,"3's)
Bbw
- jessejamesdallas
Exactly...Bozo wrote: ↑November 16th, 2021, 5:53 pm@jessejamesdallas does all his own installs...Bigbadwolfb4u wrote: ↑November 16th, 2021, 5:14 pm I may consider buying a different radio,but also am thinking about the glove box which was mentioned in a past post, however having to lean across the seat to change the channel or work the clarifer on ssb
Thanks
bbw
- Handle: El Vagabond
- Real Name: Derek Funk
- Call Sign: 884
- Antenna: Browning br-29
- Radio: Cobra 29ltd classic nw, cobra 25ltd classic, Cobra 2000gtl, galaxy dx949
- Real Name: Thomas
Seriously appreciate your time and help
Thank you, BBQ, 73's
- Call Sign: 884
Post Merge Complete
Added 1 minute 22 seconds after previous.
This is the only one I have at the moment. I’ll take some more today.
- Real Name: Thomas
Again, thank you.
3's BBW
- Call Sign: 884
Post Merge Complete
Added 1 minute 37 seconds after previous.
Pic one
Post Merge Complete
Added 33 seconds after previous.
Pic two
- Call Sign: 884
Post Merge Complete
Added 57 seconds after previous.
Sorry for the poor quality pics
- Real Name: Thomas
3's BBW
- Call Sign: 884
- Real Name: Thomas
Thank you
Return to “Mobile 🚗 / 🏠 Base Install Help”
- Welcome and Community
- Skip Shooter's Paradise
- ↳ General Discussions
- ↳ Watergates & Videogates
- ↳ Shooting Skip
- ↳ Hall Of Fame
- ↳ Journal
- Radio Help
- ↳ Intro To Radios 101
- ↳ General Questions
- ↳ Base Setups
- ↳ Competition Rigs
- ↳ Charging System
- ↳ Mobile Setups
- ↳ Antenna Help
- ↳ Microphone Info
- ↳ Radio Modifications
- ↳ Sideband (SSB)
- ↳ Tube Radio Equipment
- ↳ Other Technical Questions
- ↳ Miscellaneous Radio
- Buy / Sell / Trade
- ↳ For Sale Area Rules
- ↳ For Sale Area
- ↳ eBay Shopping
- ↳ Amazon Shopping
- ↳ Trade Equipment
- ↳ Wanted Radio Equipment
- ↳ Positive Feedback
- Off Topic
- ↳ Miscellaneous Chat
- ↳ Computer Help
- ↳ Signature Test Area
- The White House
- ↳ Ask Marv
- Home
- All times are UTC-06:00
- Cookie-Settings
- Delete cookies
- About us
- Downloads
- Contact us
