Galaxy DX-2547 suddenly low output, HELP?
adamf
Handle: Adam
Real Name: Adam
Call Sign: W4AJF
Radio: Browning Golden Eagle Mark IVA
#407933
Post by adamf »
Hi all, I have a DX-2547 that I use every so often and have not used it in a couple of weeks and find that output is extremely low. On AM it puts out about 1/2 watt dead key and swings to like 3 watts with modulation. SSB swings to about 3 watts as well. It used to put out like 8-10 watts dead key and swing to 15 or so on AM and SSB swung to like 20 watts. I am fairly handy and not afraid to try anything, can someone tell me what most likely the problem is or how I can check and/or what to replace?
Thanks for any help...Adam
Post Merge Complete
Added 3 hours 33 minutes 56 seconds after previous.
Hi all, so the radio has 2 finals, IR5620's and I replaced those 2 but no change? Can anyone help? Thanks, Adam
Post Merge Complete
Added 34 seconds after previous.
Meant IRF520's
Usually if the final goes the driver will show some output but not like your saying. I would check the voltage going to the finals, it seems to me that is the issue. Could be the internal power supply too, easy check there is to hook it up to an external supply. I think CB Tricks has a service manual with the specs.
adamf
Handle: Adam
Real Name: Adam
Call Sign: W4AJF
Post by adamf »
Hi, I am running it on an External power supply but it's the same. I am hoping someone out there knows what component(s) it may be. Thanks, Adam
nosaj
Handle: nosaj
Real Name: Jason
Radio: cobra 29 ltd
Post by nosaj »
Try outputting into a dummy load and see what your output is.
nosaj
adamf
Handle: Adam
Real Name: Adam
Call Sign: W4AJF
Post by adamf »
I only always test to a dummy load. Thanks, Adam
