New RCI 2950 CD
cecil
Handle: Tree Farmer
Real Name: Justin
Antenna: Sirio Tornado
Radio: Grant LT, Cobra 148, 2950 RCI
New RCI 2950 CD
#404498
Post by cecil »
I received my new 2950 in the mail the other day from GI Joe's. Easy radio to navigate and the large frequency display is nice too. Only thing i don't like is that it has more white noise than what my Grant has. Switching between the two, i can definitely tell a difference. Anyone have any remedies?
73's
Waving from the sugar maples in central MA!
:chores-chopwood:
304 a.k.a Tree Farmer
Grant LT
2950 RCI
Cobra 148
It is a big difference in circuitry between those 2 radios, for one the Grant doesn't have to be as wide open to receive 10 through 12m frequencies, plus no FM circuit. I have found the Rangers are pretty sensitive in receiving low signals. To help eliminate some (man made noise) check around the house for interfering signals. Wall warts, fluorescent lights, some LED's, laptop chargers, etc., might not even be in your house but any neighbor within a distance on the same transformer. You could try a "DSP" speaker to clean up some of the receive hash.
Gunner357
Handle: Gunner357
Real Name: Rick
Call Sign: KE8PSI
Antenna: Preditor 10k, V58 Maco base,EFHW-8010 end fed
Radio: Yaesu FT920,Galaxy 88hl, Galaxy 99v, Cobra148gtl modded, Cobra 29ltd chrome
Post by Gunner357 »
You can make yourself a SNIFFER like I did makes it easier to find the noisemakers .... Use a 6 foot wooden pole or scrap trim with 18ft Coax tie wrap the coax to the pole leaving a foot of the center wire of the coax expose off the end of the pole hook the other end to your radio start walking the room or around the vehicle when you find the the noise maker you can try added Capacitors between the POS + and Neg - if it in a vehicle (12v) to reduce the noise. A/C i never had an issue there, So not sure what to use. But just keep sniffing around you will find the noise... I made one for my mobile with an AMP and a Export Galaxy It found all the noise makers and I put CAPS on them and it really reduced the Noise
Last edited by Gunner357 on September 28th, 2020, 10:49 am, edited 2 times in total.
Yaesu FT920 (KE8PSI)
Galaxy88hl
Galaxy 99v
Cobra148 GTL w/ channel expansion
Cobra 29ltd Chrome
Magnaforce 350
Predator 10k
V58 Maco
Homemade Dipole base antenna
EFHW-8010 Multi-band End Fed Half Wave Antenna
Bombero
Handle: Boogieman
Real Name: Bombero
Antenna: 2ft Wire hanger
Radio: RCI 2950 Mirage
Post by Bombero »
Gunner357 wrote: September 28th, 2020, 9:51 am You can make yourself a SNIFFER like I did makes it easier to find the noisemakers ....
It would be a great idea to explain to him what a ‘sniffer’ is.
Bombero
383 Boogieman
Gunner357
Handle: Gunner357
Real Name: Rick
Call Sign: KE8PSI
Post by Gunner357 »
Bombero wrote: September 28th, 2020, 10:27 am
Bombero
I wasnt done yet had to walk away but hit enter without thinking sorry
Galaxy88hl
Galaxy 99v
Cobra 29ltd Chrome
Magnaforce 350
Predator 10k
V58 Maco
Bluerunner
Handle: BlueRunner
Real Name: Mike
Antenna: Starduster
Radio: Cobra 142
Post by Bluerunner »
Does the new radio have a more sensitive receiver maybe?
Bluerunner
Handle: BlueRunner
Real Name: Mike
Antenna: Starduster
Radio: Cobra 142
Try a shorted 1/4 wave stub with the shorted end grounded. Sometimes it will eliminate noise from the antenna.
cecil
Handle: Tree Farmer
Real Name: Justin
Post by cecil »
Bombero
Hey Gunner- got a pic of that sniffer...or what it it is made from?
73's
:chores-chopwood:
Grant LT
2950 RCI
Cobra 148
cecil
Handle: Tree Farmer
Real Name: Justin
Post by cecil »
Bluerunner wrote: September 28th, 2020, 1:33 pm Does the new radio have a more sensitive receiver maybe?
? Possibly, i like SSB, and it sounds more like AM in some respects.
73's
:chores-chopwood:
Grant LT
2950 RCI
Cobra 148
cecil
Handle: Tree Farmer
Real Name: Justin
Post by cecil »
Gunner357 wrote: September 28th, 2020, 9:51 am You can make yourself a SNIFFER like I did makes it easier to find the noisemakers .... Use a 6 foot wooden pole or scrap trim with 18ft Coax tie wrap the coax to the pole leaving a foot of the center wire of the coax expose off the end of the pole hook the other end to your radio start walking the room or around the vehicle when you find the the noise maker you can try added Capacitors between the POS + and Neg - if it in a vehicle (12v) to reduce the noise. A/C i never had an issue there, So not sure what to use. But just keep sniffing around you will find the noise... I made one for my mobile with an AMP and a Export Galaxy It found all the noise makers and I put CAPS on them and it really reduced the Noise
This is set up as base. So a looped end of coax, have to try it! Maybe i can try the ferrite wraps too...I just need to find them around here. Thanks
73's
:chores-chopwood:
Grant LT
2950 RCI
Cobra 148
Bombero
Handle: Boogieman
Real Name: Bombero
Post by Bombero »
Hey..
Good info.
Bombero
383 Boogieman
Gunner357
Handle: Gunner357
Real Name: Rick
Call Sign: KE8PSI
Post by Gunner357 »
cecil wrote: September 28th, 2020, 5:30 pm
Bombero
No pic i can get one if ya want...... But its really simple 6 foot piece of wood scrap trim or a broom handle tape or wire tie 18' of any coax RG58/RG8x (the length of coax is just so you can move around what your working on or reaching for fluorescent fixtures) , Strip about a foot of the the outer insulation and braid off leaving the center wire/dielectric loose from end of wood ( the wood just acts as a long handle) attach other end to your radio that's all ya need it will pick up any electric noise
Galaxy88hl
Galaxy 99v
Cobra 29ltd Chrome
Magnaforce 350
Predator 10k
V58 Maco
cecil
Handle: Tree Farmer
Real Name: Justin
Post by cecil »
Gunner357 wrote: September 28th, 2020, 9:09 pm
Bombero
[/qu
I have some, lets say useless RG 58 laying around, I'm going to try it. Thanks 👍
73's
:chores-chopwood:
Grant LT
2950 RCI
Cobra 148
Gunner357
Handle: Gunner357
Real Name: Rick
Call Sign: KE8PSI
Post by Gunner357 »
cecil wrote: September 29th, 2020, 8:37 pm
Bombero
yeah thats what I use i had a old 1000 Wilson i cut the coax off
Reason: Fixed bbcode quote error
Galaxy88hl
Galaxy 99v
Cobra 29ltd Chrome
Magnaforce 350
Predator 10k
V58 Maco
Remington160
Handle: Remington
Real Name: Isaac
Call Sign: KK7LNT
Antenna: Max 2,000
Radio: SBE Sidebander 3
Post by Remington160 »
All the rci ranger radios have a higher white noise level on receive than the older radios.
It's just the way they are.
Some people don't like it, and some people are not bothered by it at all.
I guess what Im saying is that it's normal for these radios.
cecil
Handle: Tree Farmer
Real Name: Justin
Post by cecil »
Remington160 wrote: December 27th, 2020, 4:40 pm All the rci ranger radios have a higher white noise level on receive than the older radios.
Thanks, i guess im just used to it now. Great radio.
73's
:chores-chopwood:
Grant LT
2950 RCI
Cobra 148
Bozo
Handle: Bozo The Clown
Real Name: James
Antenna: Monkey Made MM9
Radio: General Lee Radio
Post by Bozo »
Bombero
I know what a sniffer is...
Donate here
cecil
Handle: Tree Farmer
Real Name: Justin
Post by cecil »
Bozo wrote: December 28th, 2020, 8:52 pm
Bombero
73's
:chores-chopwood:
Grant LT
2950 RCI
Cobra 148
