Frequency Drift in Galaxy Radios
ecam357no1
Handle: Guardian1948
Real Name: Edward
Antenna: Pro-Comm PT-99
Radio: Galaxy DX 959
#401492
Post by ecam357no1 »
Hi Everyone
As anyone who has a Galaxy radio knows ,they have to warn up before there on Freq. I was wondering if anyone has found out what the part or parts are that cause this. I have a Uniden 980SSB in my truck that is instant on and it cost a lot less than a DX 959. Also has anyone have a trick that they use to warm the radio up faster. I've been told that there are a couple things people do and I`d like too here about them. I even saw a picture where a guy had a heating pad on top of his DX 959 LOL. So if you have a tip or trick you use let me know.
Thanks Ed WR224
Handle: sonoma
Real Name: sonoma
Radio: President Washington
Post by sonoma »
if you go to the search this forum box you can find a lot of info on this problem. will give you a lot of info on this. may have an answer for you.
I know some have put better disk caps in line with the crystal and it helped some.
ecam357no1
Real Name: Edward
Thanks Sonoma I`ll check that out. Ed
ecam357no1
Real Name: Edward
Well I went through the search link and there was a lot on drift but not much on what causes it or how to fix it. so any info would be helpful Ed WR 224
443 Arizona
Mod Duck
Mod Duck
Handle: Double R
Real Name: Steve
Radio: madison on 5/8 wave
Post by 443 Arizona »
i dont get any drift on my new 959 but i do get bleedover across all the 40ch.
ecam357no1
Real Name: Edward
Hi Steve
I was getting bleed over from ch 22 all the way up on 38 lsb.A good friend and ham told me to turn off my ANL/BN and it cut the bleed over way back. My Galaxy is about 5 yrs.old it might help on the newer radios too.I`m close to Balto. City and sometime the Superbowl get`s really fired up.
Ed WR 224
Stoneman
Handle: Stoneman
Real Name: Junior
Antenna: One Shot Dipole
Radio: Cobra 2000 GTL
Post by Stoneman »
Every Galaxy I ever owned drifted when first turned on, it's like you get used to it.
ecam357no1
Real Name: Edward
Hi Stoneman
I know what you mean,but I`v heard tips like glueing a led bulb to the OCC crystal or putting bees wax around it. I`ve even been told to get a reptile heater and lay it on top of the radio.Just woundering if anyone has heard of anything. Ed WR224
ecam357no1 wrote: March 13th, 2020, 6:24 pm glueing a led bulb to the OCC crystal Ed WR224
Don't think an LED puts out any heat, it would need to be a regular "wheat bulb" (2, one on each side of the crystal) like in older radios and I would use shrink tube to hold it in place. You will need to unsolder the binding strap and after your done solder it back. This did work to a point but there was still some drift. Best thing would be to unlock the clarifier then have the radio aligned so the transmit/receive track to same.
Also seen a electronic crystal heater, made in he Ukraine, not sure if I want to order from there.
