External speaker squeel
Searle951
Mud-Duck Sr.
Mud-Duck Sr.
Real Name: Cameron
#393417
Post by Searle951 »
Just installed a connex 4600 in a dump truck. Have a wilson 2000 mounted on mirror. I hooked my external speaker up in the morning and worked great. By afternoon it began to get feedback and squeal with power level up on radio.
Bozo
Handle: Bozo The Clown
Real Name: James
Antenna: Monkey Made MM9
Radio: General Lee Radio
Post by Bozo »
Try turning down the mic gain
Donate here
Handle: Jesse James Dallas
Real Name: Jesse
Radio: working
Post by jessejamesdallas »
or turning off the talkback.
You could always move the external speaker a little farther away.
sonoma
Handle: sonoma
Real Name: sonoma
Radio: President Washington
Post by sonoma »
if you have the speaker wires rolled up in a ball behind the radio will also cause a squeal. move the speaker away from the radio a little as mentioned. I have even shortened the speaker wire just enough for it to reach the radio and it will stop the squeal at times.
Searle951
Mud-Duck Sr.
Mud-Duck Sr.
Real Name: Cameron
#393601
Post by Searle951 »
I will try moving speaker wire. I can turn mic gain down and be ok if rf power is turned down. If I turn power up to high get squeal no matter where mic gain is.
