External speaker squeel
- Searle951
- Mud-Duck Sr.
- Real Name: Cameron
Just installed a connex 4600 in a dump truck. Have a wilson 2000 mounted on mirror. I hooked my external speaker up in the morning and worked great. By afternoon it began to get feedback and squeal with power level up on radio.
Bozo Verified
- Handle: Bozo The Clown
- Real Name: James
- Antenna: Monkey Made MM9
- Radio: General Lee Radio
or turning off the talkback.
You could always move the external speaker a little farther away.
- sonoma
- Handle: sonoma
- Real Name: sonoma
- Radio: President Washington
if you have the speaker wires rolled up in a ball behind the radio will also cause a squeal. move the speaker away from the radio a little as mentioned. I have even shortened the speaker wire just enough for it to reach the radio and it will stop the squeal at times.
- Searle951
- Mud-Duck Sr.
I will try moving speaker wire. I can turn mic gain down and be ok if rf power is turned down. If I turn power up to high get squeal no matter where mic gain is.
