Finally!
Aughtry
Handle: Aughtry 722
Real Name: Ryan
Call Sign: K4TXN
Antenna: President Iowa
Radio: President Bill FCC
Finally!
#386226
Post by Aughtry »
Well it finally came in. A RCI 2970N4 . 10, 11, and 12 meters. Got it hooked up and hit a few folks on 38 lsb right off the bat. A little bit of umph helps when conditions aren't so great, and really helps when it's rolling. Put it away for tonight. Need to go through the manual. Going to work 10 meters with it also. Have to use the DOSY to find where 200 is to keep within limits of a Technician. I'll be on the air!
Also got the Palomar SL41 mic. I'll keep the Astatic 636L with the Galaxy working as a base.
Oh, and it's running through LMR400 coax to a Predator BadToTheBone. :biggrin:
Edit: I realize the freq is off in the pic...
Aughtry 7 double-deuce waivin' atcha from Prisontown, TX
President Bill II FCC AM/FM with President Iowa antenna
Yaesu FTM-400 with Larsen NMO2/70B antenna
Yaesu FT-891 with various antennas
Tex.Proud on IG
Amateur - K4TXN
GMRS - WQZF521
Good looking setup Aughtry, if any 10m hammie's ask you what radio your running tell them it's a Yeasu.
silvereagle1
Handle: Silver Eagle
Real Name: Mark
Antenna: Sirio Turbo 5000
Radio: President Lincoln 2
Post by silvereagle1 »
Yep, been there done that a couple years ago. Tell them it's a yaesu you'll get a great report back.
[ Post made via iPhone ] [ external image ]
President Lincoln 2
Sirio Turbo 5000 Roof Mount
567 East Tennessee
Guardsman
Real Name: Joel Jennings
Antenna: Wilson 1000
Radio: Ranger RCI 2970N4
Post by Guardsman »
Great setup! I love my 2970N4, I'm sure you will also.
