Not now
Get a better experience by installing our web app!
Hide
How to do it?
In Safari, tap on the menu bar. Scroll down the list of options, then tap Add to Home Screen.(If you don’t see Add to Home Screen, you can add it. Scroll down to the bottom of the list, tap Edit Actions, then tap Add to Home Screen.)
Connect with CB radio enthusiasts at CB Radio Talk Forum. Fuel your knowledge, unlock secrets, and engage in discussions. Join a vibrant community of like-minded individuals and explore the exciting realm of CB radios.
anyone have experience with a phantom power supply.i have a studio microphone and it runs on phantom power not sure how to hook it up. it has mic. in mic.out has xlr plugs that plug in to the box. then plugs into power supply.
any help would be appreciated. ive watched you tube videos but they only show how to hook it up to a computer
thanks.
What voltage does the instruction/manual say the mic needs to operate? A lot of "studio style" microphones require 48v and they get the power off the sound board it is hooked to. To hook one up to a radio the audio should feed through to PS via an output, you will have to use a handheld or foot pedal for the PTT switching like ones used on a Heil mic.
yes i have all of it. yes its 48 volts i have a heil stand with the ptt switch also have the foot petal
bought 5 premade cords for it. just need to hook it to my 48 volt phantom power supply
thanks
If you have a cord that goes from the mic to the PS than half your battle is won, follow the schematic or instructions for the audio and ground hookup from the PS to the radio. Sometimes a diode is required to keep any power feedback on the ground side when making up the PTT.
there was no instructions in the box. i have 2 xlr cables male and female. and the cord that goes from the mic. to the radio. and the ptt stand.. ill try to figure it out
thanks youngblood
