175 WATT MAGNUM S9 ?????
mudder
#37926
Post by mudder »
I was reading someplace that magnum is coming out with a 175 version of the S9.Does anyone know when this is coming out?sounds interesting. :twisted: :D 8)
mudder
#37927
Post by mudder »
opsd sorry i meant to say 175 watt S 9.
Looney
#38181
Post by Looney »
i don't think so maybe with power
Mr. 9k9
#38556
Post by Mr. 9k9 »
I heard the same thing, but that was quite a while ago. Anyone tried the 80 watt version?
DJ
Gadfly
#38619
Post by Gadfly »
While it sounds like one is really "smoking" with 175 watts, compared to 80 watts, you will barely tell the difference! It is more psycological than real! :shock: Just for grins and giggles, it actually takes FOUR times the original power to make any difference in the received signal at the other end! 6 DB= one S-unit so if your 80 watts is being received at the other end at S-9, it won't even move the meter! To gain ONE S-unit you would have to be pushing 320 watts to move the needle up ONE more unit. You are effectively gaining.......................nothing. Well, maybe in our mind! :D Power isn't all it is cracked up to be! It just SOUNDS good!
73
Gadfly[/i]
Diesel
#39822
Post by Diesel »
I run the Magnum S-680 in my big truck. It will WALK THE DOG AND KICK THE CAT for sure.
Looney
#39829
Post by Looney »
walking the dooooog draging the cat
SmallTruckBigRadio
#39879
Post by SmallTruckBigRadio »
Yep,
I find that the 40 watt radios pushing separate amps are very hard to beat.
But, I hear that some trucking companies dis-allow separate amps. I guess that's why there is a market for the internal power.
Diesel
#39951
Post by Diesel »
Yeah, there is some companies that frown on having a seprate amp installed. There probably afraid that the amp won't get installed right and start having problems with the wiring.
North Texas Mudduck
Post by North Texas Mudduck »
and it really makes a guy mad when you walk on him with a cobra 29 ltd classic with roadking 56 and a 1pill box
when he just gave up his ghost to be able to afford the new radio and first day out the box he gets walked on
i feel bad
Diesel
#40097
Post by Diesel »
It's fun to walk on people tho. Espeacially the ones that are being **Censored**"S to everyone!!!
Phaze91460
#40101
Post by Phaze91460 »
Well, in defence of built in amps, I have a Connex 4600 Turbo SWP and I can tell you that no cobra 29 with a 1 pill ever walked on me.
And more power will not make you louder but will push you signal further. On the highway most conversations are short because of the RF pressure on 19 and many of the drivers you are talking too are driving away from you at speed. With more power you can talk to them further but they will have to have enough power to get back to you.
If skip is your thing then get a seperate amp and go for it. If you are just talking local and mobile then the built in amp is a great option. I have radios both ways.
SmallTruckBigRadio
#40129
Hello Phaze,
I'm with you on that one.
Then there's the whole AUDIO aspect of "transmission dominance" (aka: walkin' on em')
