SDR
Blue MTN
Radio: Cobra 25LTD
SDR
#384731
Post by Blue MTN »
I was talking to my brother who is into the sdr stuff which got me curious as to what the easiest way to tx with sdr. He just has the dvb dongle from Nooelect. Which I believe you just receive with which would be fun to use as a scanner for the emergency frequencies around here. But I was wondering what a cheap easy way would be to use the sdr technology as a transceiver as well well?
Cobra 25LTD installed in 2007 Jeep Wrangler
Teaberry "t" Dispatch- new
Re: SDR
#384747
There is no cheap way to transmit, an SDR is just a receiver but there are SDR amateur radios that are expensive. You will find some more info on the subject by using the search feature.
Blue MTN
Radio: Cobra 25LTD
Re: SDR
#384759
Post by Blue MTN »
Yeah I see the expensive radios. I decided to give the sdr receiver a try. Bought one online tonight. I found sdr touch for android so using a otg cable you can plug the dongle into your android device. So I'll see how well this works once everything arrives!
Re: SDR
#384773
I bought one of the cheap kits and built it, they work okay, you will have to do some research on ones that will work for you. I just bought a SDRPlay RSP1 , the website has there own program to download making it much easier to program and adjust. It costs a little more but worth the loss of aggravation.
DevilDog66
Real Name: Guy
Antenna: Sirio5000/Nagoya77B
Radio: 980SSB/YaesuFT3200DR
Re: SDR
#384923
Post by DevilDog66 »
I know a few HAMS around here that have the DV4M dongles and they say they work great. They use it for their D-Star nets. I myself am into System Fusion. I'm considering a dongle hooked up to an Raspberry PI. The coolest thing I think is that for around 200 bucks you can TX in any digital mode you want. HOWEVER, I may get the DV4M mobile transceiver as a Christmas gift since I had heard that these rigs go for like 900-1200 dollars! :crying-blue:
Semper Fi! HML-767 NOMADS 1985-1990/Mobile: Uniden 980 SSB/Sirio Performer 5000/Hand Held Uniden HH401/K40 mag mount/Radio Shack TRC-482/Cobra HG Power mic/SRA-198 mic
Blue MTN
Radio: Cobra 25LTD
Re: SDR
#384928
Post by Blue MTN »
I've been playing around with mine when I get a free minute. I can receive the noaa weather channels and fm radio great. However I still need to play around with dsd+ a little more t decode the digital signals. So far it's been a fun little project for $25 lol
295 antenna
Handle: 2950 or 295
Real Name: Charles Reney
Antenna: patriot, Discone
Radio: Stryker 955 , Browning Mark iv
Re: SDR
#386250
Post by 295 antenna »
hey Blue MTN i just got my nooelect sdr but im having alot of trouble setting it up when i down loaded the driver (which was abit of doing)now being sent to a web site for a operating tool ? is your brothers set up. im using windows 10 . if so have any suggestions?
Re: SDR
#386253
The driver download will send you to "Zadig", there you have to pick the right driver, it is a little complicated. NooElec website has the downloads you need to get started.
295 antenna
Handle: 2950 or 295
Re: SDR
#386257
did all that now why wont it start up ,I cant find it in my computer
Re: SDR
#386258
Are you using HDSDR to view the spectrum?
295 antenna
Handle: 2950 or 295
Re: SDR
#386261
heck i dont know .i did everything they told me to do but i still cant find the right device on the drop down for drivers .
295 antenna
Handle: 2950 or 295
Re: SDR
#386262
ok driver installed now to find the next step
Re: SDR
#386264
Hmm, open HDSDR, in the bottom left corner there is a menu, click "options", the top is "select input" click it, click on "ExtlO DLL", now back to the menu and click "start". It should run the dongle.
295 antenna
Handle: 2950 or 295
Re: SDR
#386268
Got it !!! I just uninstalled everything then started over and boom ...thank you MD
Re: SDR
#386270
Cool! Sometimes starting over is the thing to do, glad you got it working. I've been watching mine on 2m. Once you play with the you got you will probably look to upgrade to one that will give you the HF bands, I would recommend the SDRPlay.
295 antenna
Handle: 2950 or 295
Re: SDR
#386282
OK update on the Nooelec sdr it works yes and no i have a water fall stream but its acting like its not connected to the dongle. in fact its picking up sound from the computer microphone. Wierd noises and some of the functions dont seam to be working .
Re: SDR
#386283
MDYoungblood wrote: July 10th, 2017, 5:38 pm Hmm, open HDSDR, in the bottom left corner there is a menu, click "options", the top is "select input" click it, click on "ExtlO DLL", now back to the menu and click "start". It should run the dongle.
Try this again, it sounds like it's using the the mic line instead of the dongle.
295 antenna
Handle: 2950 or 295
Re: SDR
#386285
ok thats the issue i opened up the options menu and did what you said and it wants me to choose a device which is not there ? i think the computer cant see this dongle
Re: SDR
#386291
If you can't click on "ExtlO DLL" then the dongle isn't seen, correct. try reinstalling it again but unplug the dongle first.
295 antenna
Handle: 2950 or 295
Re: SDR
#386292
i can click on it but then a window opens up for me to select some thing..but what i have to find a certain folder ?
Re: SDR
#386293
When that box pops up it should show a file for the dongle.
295 antenna
Handle: 2950 or 295
Re: SDR
#386294
OK i am sooo happy now i watched couple of youtube videos and discovered i needed to down load a batch file from airspy as an admin. did that and everything is working fantastic already got some station in and ill probably playing with this last thing at night and first thing in the morning. This was my first experience with sdr and im hooked lol.Thank you MD for your help
Re: SDR
#386885
Here is a website that explains some of the tricks, http://tylerwatt12.com/tips-for-using-sdr/ .
295 antenna
Handle: 2950 or 295
Re: SDR
#386887
Very nice Thanks again MD
Blue Ox2
Handle: Blue Ox
Real Name: Mike
Call Sign: KC3LAV
Antenna: DR-Dipole, Copper "J"-Pole, IMax 2000, MFJ 1740, and a "Slinky" 40M dipole
Radio: President McKinley&Washington+142GTL Direct Injected by Leadfoot Labs
Re: SDR
#386888
Post by Blue Ox2 »
295 antenna wrote: July 9th, 2017, 11:42 am hey Blue MTN i just got my nooelect sdr but im having alot of trouble setting it up when i down loaded the driver (which was abit of doing)now being sent to a web site for a operating tool ? is your brothers set up. im using windows 10 . if so have any suggestions?
Chares,
Instead of fussing with SDR#, I got CubicSDR at Cubicsdr.com and just downloaded to Windows 10 and followed the prompts.
It will still take some learning but it is working and I have connected an external hard drive to the puter so I can keep
a lot of the stuff off of the laptop.
I am still learning about adding plug-ins so I can use the ham up gear I got and the shortwave gear I have connected as well.
I have the dongle hooked to my rooftop antenna, too.
73
Mike
How do you do from Blue Ox2
KPA223 on the Galaxy DX 2517
