Uniden Grant xl
GOTA Go
Uniden Grant xl
#38072
Post by GOTA Go »
After I bought my General Lee I decided to pull out of my closet a Uniden Grant I had bought of few years back and put in my pick up. Is this a decent radio ? I know it can't touch my general lee but can it be made to push any amount of watts. It was peaked and tune at a shop in Hickory. However I notice when I key up it has a very large dead key and know change on the meter when you talk. No swing at all. Did the shop tune it wrong or is there a different ways to tune radios. Do I need to find someone else to look at it.?I would like to keep it because it has upper and lower side bands in case I get into that.
BigBopper
#38078
Post by BigBopper »
good radio,,if it wasn't set to run an amp, the shop just turned up the watts to max,,,when you set for an amp,,,,,you want low dead key and high swing,,,
GOTA Go
Post by GOTA Go »
Thanks, I thought that what it might be.
HI-TECH
#38144
Post by HI-TECH »
turn up? lol ive had to turn mine down to run both a low drive aqnd a high drive amp... awsome radio will never sell this one or give it away,
