Alternator help
Rabbit Ears
Handle: Rabbit Ears
Real Name: Cliff
Call Sign: WW153
Antenna: Hygain Penetrator 500
Radio: RCI 2995DX CF
Alternator help
#354403
Post by Rabbit Ears »
I've got the standard alternator on my 1996 f250 7.5L.... Can I kit that alternator for higher output. I'm pulling an RV. I can do the work.
Help....!
USA FOREVER
RCI 2995DX CF (PRIMARY BASE)
Turner Super Side Kick
RM Italy KL300P (A/B modded) in truck :twisted:
BIRD 43P
HY-GAIN SPT-500 antenna
alfred56
Handle: 581
Real Name: Andrew
Antenna: sirio p5000
Radio: galaxy 98 vhp
Re: Alternator help
#354502
Post by alfred56 »
What do you mean by kit it. You cab get one I have on from an online source in my 84 200a for no plan on adding another
Sent from my DROID RAZR using Tapatalk
Re: Alternator help
#354546
I not sure they even make rebuild kits anymore but I remember them from years ago. The kits (bearings, brushes, etc.) had new diodes and rectifier bridge and they did increase the amperage some but you are using the same windings. I think it would be best to find a rebuilt unit, they almost have twice the stock amperage.
rickk
Real Name: rick kay
Antenna: Francis/Breedlove
Radio: Galaxy DX979
Re: Alternator help
#357652
Post by rickk »
NAPA often has HO alternators in their books.
If you are pulling an RV, sounds like you would be driving lots of miles. Plenty of time for charging. Your circumstances might be unique but wondering why you need more alternator output? Most high current needs are intermittent use.
Might possibly be better to spend money on a bigger primary battery and also install an auxiliary battery. Anderson Power Products makes a nice, efficient, painless-install battery isolator if needed. There should be a ton of room on your right side frame rail to put a really big auxiliary deep cycle battery. The RV I would assume has plenty of room for batteries as well.
Do you need more power when you are driving, or need more power when you are parked?
Rick
Rabbit Ears
Handle: Rabbit Ears
Real Name: Cliff
Call Sign: WW153
Re: Alternator help
#357675
Yes, I'll be getting the bracket and the larger alternator. Will also be using a pair of Trojan T105 wired in series for the camper. The old 1996 F250Hd 4x4 has a tow kit. When I turn the key off, that isolates the camper from the truck.
I'll go dual Optima AGM batteries in the front end of the truck. Tough and spill proof too. That'll do quite nicely for the work lights and the KC lights.
USA FOREVER
BIRD 43P
