Realistic DX-380 question.
- Sporty Mike
- Real Name: Michael
- Radio: Alot of 'em!!
Hey guys , I have one of these little SW recievers and was wondering how exactly to go about connecting a longwire antenna to it? It has a small jack like a headphone jack marked "ext. antenna" so I was a little curious as to the best way to hook a longwire to it.
Thanks,
Mike
Thanks,
Mike
SWL radios are really easy to setup an antenna, just about anything can be used as it is receive only, rain gutter, siding, metal window frames. A long wire is simple, you need 2 insulators, the wire, and a run of coax. put one end and insulator out in a tree, fence post. etc. high enough to be out of the way, bring the other end to the house, insulator at a high point and drop the wire to the ground. At the ground is where you want to connect the coax, center to the wire and shield to a ground rod, etc. run the coax to the radio, 50 or 75 ohm, doesn't matter it's just receiving, I used an F (TV) connector on the radio end so as not to get it confused with transmitting antennas and for that radio I would get one of these adapters,
[Please login or register to view this link] .
Length of wire isn't critical but with most SWL the longer the better.
- Sporty Mike
Thanks Youngblood , can you get those adaptors with a SO 239 instead of the TV connector ? If so that would be perfect!! And where can I get them?
Mike
Mike
They may make them but I haven't seen one, they do make a female F connector to a SO239. You can make a jumper with a PL259, 3.5mm mono plug, and coax.
- Sporty Mike
The one like you showed in the pic will work , It's just that I already have a longwire made with a 239/259 connector.
Mike
Mike
