Tuners
Re: Tuners
I doubt you'll need one for 6m but it depends on what you plan on using for an antenna. Heck, a dipole, yagi, or other resonant antenna for 6m wouldn't need a tuner. Most run antennas designed for 6m and more often than not don't require a tuner.
Palstar and Alpha are considered by most hams to be the best. There are a couple of European models out there that are awesome too. But better plan on spending a small fortune on them because they are going to set you back a pretty penny. Especially new. I'm a fan of the old Dentron, Drake, Ten-Tec, Nye-Viking, Heathkit 2600, and a few others. There are darned few MFJ tuners I would use...but hey, if your budget only allows one then go with it. Some of the T-network tuners they are making with a tapped inductor are pretty good and will tune most things...plus they can be had at a reasonable price.
For auto-tuners, Palstar, Alpha, and Tokyo Hi-power are probably the best...but expensive. SGC is decent, and LDG & MJF probably useable...just depends. I had an LDG auto tuner for my Icom IC-7000 and hated it. It was probably the worse tuner I'd ever bought and just wouldn't buy another. Their bigger tuners are decent though (and allot more expensive).
I use an old Dentron 3kw tuner in the shack with a tapped inductor though. It's been "Old Reliable" and I just couldn't imagine parting with it. I usually keep a Ten-Tec L-Network 2kw model 229 or 238 for my stand by tuner as well. They can be had pretty reasonably and are a good quality tuner that won't break the bank (used).
You might consider checking out eham reviews and get familiar with what's out there. Keep in mind that many of the reviews have little to do with the equipment quality and function and more to do with operator convenience. While most tuners work the same, they each have their own little corks about them.
Hope that helps a little.
Re: Tuners
Post by KG4KGW »
The very best thing to have is a resonant antenna. It will beat a tuner any day of the week! 6 meters is such a small band if you get your antenna resonant in the middle it will usually be better than 2:1 on the edges as well. 10 meters you start to get a little long in the tooth since it covers a much larger band portion. Most people operate in the 28.5 area of the band since that is where the Tech's have privileges. However there are some repeaters further up the band. By the time you get to 20 meters you will certainly need a tuner to work the entire band. Even a resonant antenna there will only be resonant in the CW or Phone portions of the band and not both.
Tuners are very simple to build and in the past were usually one of the first projects that a new Ham would build. The parts are easily constructed or purchased and you can build a 1000w tuner for about 30 bucks. Putting a good meter and selector switches costs the most.
If you intend to stay under 300w and want an off the shelf manual tuner I highly recommend the MFJ-949E. I've run one without problems for years. I also have a Vectronics manual tuner for mobile use, but it sees little action. Seems to work just as good as the MFJ and they are made by the same company.
- Real Name: Ryan
- Antenna: Several
- Radio: Realistic TRC-458
Re: Tuners
- str8stroke
- Real Name: Ric Flair
- Antenna: 1/16 Wave Dipole
- Radio: Gold Cobra 29LTD
Re: Tuners
Post by str8stroke »
- str8stroke
Re: Tuners
Re: Tuners
Post by KG4KGW »
Keep in mind 1.5KW of RF isn't the same as 1.5KW of electricity.
- Slyguy
- Real Name: Sly
- Antenna: Yes
- Radio: Kenwood, Yaesu, Icom
Re: Tuners
Care to explain this?KG4KGW wrote: Keep in mind 1.5KW of RF isn't the same as 1.5KW of electricity.
Zero Six Three
Sherman Texas
- str8stroke
Re: Tuners
Slyguy wrote:Care to explain this?KG4KGW wrote: Keep in mind 1.5KW of RF isn't the same as 1.5KW of electricity.
I second that. Please explain that one.
Re: Tuners
Post by KG4KGW »
The simplest way to explain the difference between an electrical watt and a watt of RF energy is that RF energy has the additional component of a magnetic field. This is not to say that electricity in itself does not emit a small amount of magnetic field.
An RF field has both an electric and a magnetic component (electric field and magnetic field), and it is often convenient to express the intensity of the RF environment at a given location in terms of units specific for each component. For example, the unit "volts per meter" (V/m) is used to measure the strength of the electric field and the unit "amperes per meter" (A/m) is used to express the strength of the magnetic field.
This is why we don't simply sample our output power with a volt / ohm meter. It is not a direct measurement of electrical power, but a measurement of RF energy which is electrical power present in the form of a magnetic field.
If it were any different you could simply hook your welder up to your antenna with the appropriate diode in place and have instant wattage in the cottage. This is why we have to carefully design tuned circuits that create reactance.
Hope this helps.
- Slyguy
- Real Name: Sly
- Antenna: Yes
Re: Tuners
I still don't understand how this pertains to a g5rv being able to handle legal limit wattage.KG4KGW wrote:Slyguy wrote:Care to explain this?KG4KGW wrote: Keep in mind 1.5KW of RF isn't the same as 1.5KW of electricity.
Hope this helps.
Zero Six Three
Sherman Texas
- Real Name: Ryan
- Antenna: Several
Re: Tuners
Re: Tuners
Post by KG4KGW »
Depending on the make of G5RV (yes they are not only made in one size or by one manufacturer) the standard (original) is rated at 2.5KW. Before I put a KW into mine I'd read the specs on the one I purchased.Slyguy wrote:
KG4KGW wrote:Keep in mind 1.5KW of RF isn't the same as 1.5KW of electricity.
I can easily double the legal limit on my doggie wire inverted vee and if I offset the center feed could make a homebrew g5rv with the same materials. Although I'd have to look up the measurements to know for sure. If I were going to take the time to make another antenna it would likely be a double bazooka or a Carolina Windom. There are just so many choices out there!
Re: Tuners
Post by KG4KGW »
- Night Crawler
Re: Tuners
Post by Night Crawler »
Why do you you need a foot swtich the older transcievers have a direct cnnection for it and for the newer ones an inerface is available.rhino458 wrote: Only one problem, I left the foot switch on the ground in the garage and the good ole mans best friend chewed it up, so off to HRO today to locate a RCA plug style foot switch.
- Slyguy
- Real Name: Sly
- Antenna: Yes
Re: Tuners
On my rig I use a foot switch to key the radio. The radio in turn keys the amp. Just keeps my hands free to take notes or whatever.Night Crawler wrote:Why do you you need a foot swtich the older transcievers have a direct cnnection for it and for the newer ones an inerface is available.rhino458 wrote: Only one problem, I left the foot switch on the ground in the garage and the good ole mans best friend chewed it up, so off to HRO today to locate a RCA plug style foot switch.
Zero Six Three
Sherman Texas
Re: Tuners
Post by KG4KGW »
I ordered a PR-781 yesterday though so as soon as I can I've got to get a mixer to interface it with the radio. Currently I'm using the phantom power supplies output to wire it to the radio microphone input, but I may have to move this to the back of the radio through the rear audio input jacks.
I've grown very comfortable using the foot switch for keying.
- str8stroke
Re: Tuners
Re: Tuners
Post by KG4KGW »
I know this may seem like an odd question, but do you have 2 feet? Key with 1 and kick with the other.str8stroke wrote:I have to keep my foot free to kick my crazy cat!
Just in case you only have 1 foot to use, you can always keep a spray bottle to squirt the cat with should you need to do it.
- Slyguy
- Real Name: Sly
- Antenna: Yes
Re: Tuners
Take off the pink fuzzy slippers and the cat will leave you alone.str8stroke wrote:I have to keep my foot free to kick my crazy cat!
Zero Six Three
Sherman Texas
Return to “Miscellaneous Radio”
- Welcome and Community
- Skip Shooter's Paradise
- ↳ General Discussions
- ↳ Watergates & Videogates
- ↳ Shooting Skip
- ↳ Hall Of Fame
- ↳ Journal
- Radio Help
- ↳ Intro To Radios 101
- ↳ General Questions
- ↳ Base Setups
- ↳ Competition Rigs
- ↳ Charging System
- ↳ Mobile Setups
- ↳ Antenna Help
- ↳ Microphone Info
- ↳ Radio Modifications
- ↳ Sideband (SSB)
- ↳ Tube Radio Equipment
- ↳ Other Technical Questions
- ↳ Miscellaneous Radio
- Buy / Sell / Trade
- ↳ For Sale Area Rules
- ↳ For Sale Area
- ↳ eBay Shopping
- ↳ Amazon Shopping
- ↳ Trade Equipment
- ↳ Wanted Radio Equipment
- ↳ Positive Feedback
- Off Topic
- ↳ Miscellaneous Chat
- ↳ Computer Help
- ↳ Signature Test Area
- The White House
- ↳ Ask Marv
- Home
- All times are UTC-06:00
- Cookie-Settings
- Delete cookies
- About us
- Downloads
- Contact us
