BobCB wrote:I would think it would be a good scanner. I have a few Radioshack and Uniden scanners of that age and they are great for non-800mhz scanners. Clean receive and loud audio. With a good mobile antenna, you should do fine with it mounted in your car.
As for dimensions, I couldn't find anything on the Uniden, but I did look up its Radioshack counterpart that you listed and it has dimensions of 6.3(W) x 1.6(H) x 7.4(D) in.
Thanks for the info.
I have a Uni/B-cat 560xlt that I pulled out of storage recently, sounds great, receives well, but it only has 16 channels and the small back-of-unit antenna is only good for local stuff. Since I've had good luck building a 11 meter dipole, I might try the same no-cost antenna build approach for the 560. Back in my days with civil defense, I used to run with 1 hand held RS Pro-34 scanner and the Pro-2026 with an antenna specialist fender mounted MON53 scanner antenna. I wish AS still made those antennas. It was about 4 foot with a loaded coil in the middle, strong, and survived many "transplants" to my other cars over the years and pulled in everything, 25mhz to 800/900 mhz.
73's
