D&A Falcon 400
- Aviator
- Handle: Aviator
- Real Name: Richard
- Call Sign: 2CT687
- Antenna: 102" SS Whip
- Radio: DX66V
D&A Falcon 400
Came out of a 50's model IH semi. The original paint is non-existent but the tubes inside look new. Also came with a buttload of 6LQ6 tubes. Being as this is a mobile amp, would it be financially acceptable to convert it to a base setup or should i just sell it? Also, the tubes are NIB...or what's left of the original boxes. Thanks for any info anyone can provide. I really have no use for a mobile like this, so if it doesn't make sense to convert it and anyone is interested.....feel free to PM me.
Six-Eighty-Seven Leesburg, Florida; Most Active On 38LSB & 27.555USB
"Yea, it's a 102" SS Whip 25 Foot In The Air.....No I'm Not Kiddin'"
- radio11
- Real Name: hank
- Antenna: stacked 3/hor.
- Radio: yaesu 757/kenwood ts
Well,how many tubes are in the amp?any tube amp is worth the time to re-build/restore.u can always build an power supply for it and run it base.and they are sure sweet in a mobile set-up.dont draw near as much current as the s/s amps.
- Aviator
- Handle: Aviator
- Call Sign: 2CT687
- Radio: DX66V
There's 2 6JT6's and 4 6LQ6's. I'd be interested in knowing how to convert, then i can run this and my Palomar 90A together.
It can be done, but its gonna take a decent power supply to run it. A 2x4 6lQ6 should get ya about 500w if they are all in good shape!! I am going to PM you....
Snowman
Snowman
- Night Crawler
Change the power tranformer in it to one that has a 120vac primary then you wouldn't need a 13.8vdc 100amp supply.Aviator wrote: I'd be interested in knowing how to convert
- Aviator
- Handle: Aviator
- Call Sign: 2CT687
- Radio: DX66V
Where the heck do I find one of them?
- Night Crawler
Here you go [Please login or register to view this link]
The only other thing that will have to be done is to change the HV rectifier in that amp from a fullwave bridge to a fullwave doubler which is easy.
- Aviator
- Handle: Aviator
- Call Sign: 2CT687
- Radio: DX66V
Thanks Nightcrawler...gonna take a short break from CB, gotta figure out how to re-mount my antenna. Thanks for the info and I'll get around to it sometime.
- Aviator
- Handle: Aviator
- Call Sign: 2CT687
- Radio: DX66V
10 bucks??? That's it? I'm a novice so what does that swap entail?
- Aviator
- Handle: Aviator
- Call Sign: 2CT687
- Radio: DX66V
I haven't even messed with it....and YOU NEVER CALLED ME BACK HA HA HA
- Aviator
- Handle: Aviator
- Call Sign: 2CT687
- Radio: DX66V
Nightcrawler, can you provide me with any information on this conversion? I know I know......I feel like I need my hand held lol but this is new territory for me.Night Crawler wrote:Here you go [Please login or register to view this link]
