Need some help
Archy
Real Name: Alexander M Schwartz
Need some help
#293346
Post by Archy »
Hi, im new to cb radios and i really want to get into them but i cant get my setup to work. First i have a uniden pc78elite with a wilson whip antenna 4ft 1,000 watts. I have the antenna mounted on my side rail of my truck its grounded and i have an swr tuner but i cant tune it or even get it in a low enough range to use. It also is picked up on my cars speakers so i can hear myself talking. any help would be great!
drdx
Handle: dollar-98
Real Name: David
Antenna: Many
Radio: Many-
Post by drdx »
Welcome. First of all, do you know how to use the meter? Key up, with it on calibrate, turn the calibrate knob to cal, switch to reflect and you should get a reading, on most meters. What is the swr? If the antenna is too close to the cab you may have an issue. Also, make sure the coax is not shorted out. You can do this with an ohm meter. Can you hear other stations?
Tobin
Handle: Androx
Real Name: Andy Tobin
Call Sign: 9TC02
Antenna: A99
Radio: Ranger 2995DXCF
Post by Tobin »
You have some major setup issues.... Are both radio and antenna new or used..? What condition is the cable...? I know some vehicle radios are susceptable to RFI from CB's but not many. Am is usually bled over easily. I recall an ampped radio bleeding over a car radio a lot....
I am asking these questions as this is what the techs will need to know in order to further troubleshoot the problem (s)
I am novice but I know sometimes what questions need to be asked in order to verify what direction the tech needs to go. You will find some good ideas very soon as this forum is full of experienced techs and they are most helpful....
I am sure they will have more questions for you also.... Hang in there...... You will be helped much more very soon....
TOBIN
Base station: Ranger 2995DXCF
Antenna: Antron 99
VIVAT JESUS ~ Jesus Lives
Archy
#293351
Post by Archy »
thanks for the help, the radio is used the antenna is new and the coax cable is about 3 months old. i do know how to use the swr meter since i tuned my last antenna but lately i haven't been able to get this one tuned
DanTaylor
Real Name: Jason
Radio: Galaxy 959
Post by DanTaylor »
Only thing I can thnk of is make sure when tuning you are making very small adjustments. Also make sure all the connections are good and that everything is in good shape overall.
WORK TRUCK Galaxy 959 peaked and tweaked with echo
PLAY TRUCK Cobra 29 NWST peaked and tweaked
BASE Uniden Washington with a swing kit and a D-104
